oh ok... your phone passes and is saved from the trials and tribulations of failure...
on the other hand, flip your brothers phone the bird next time you see it for me...
THAT IS THE PRICE YOU PAY FOR FAILURE!
Also, do you get what I said about the RROD plates?
Hahaha nah...
RROD stand for 'Red Ring Of Death' which is what Microsoft dubbed the failure warning lights on the Xbox 360... Seeing as how 1/3 of those fail (like Ferraros)(and the 360 has round tail lights, so it works while it's not failing too!) I thought it would be fitting :)
do eeeeet
Everyone will think you're clever!
wait...
Am I missing something?
You have an r33....then bought a massarati and now a ferrari??
wtf man?
how do you have thatg much money to waste on cars!!!!! I want money like that darnit.
self employed + no sleep + up to my eyeballs in stress + no spare time + living out of a suit case + travel interstate at a drop of the hat = interesting cars + other more important things
  • 2 months later...
I can't tell if its a maybach or a coppied chineese car company.
If its real its worth well over $1 000 000 AUD before stamp duty, on road costs ect...
Power=450kw @ 4000rpm
Torque = 1000nm @ 2000-4000rpm
100% sure that's authentic. There was a Maybach 57 at the motor show some years back and it looks exactly the same. If I was in that market I'd buy a Phantom over one of these things for sure. It looks far too much like an S Class.
Nice spot. :( Where was it?
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
