  • 1 month later...
Forgot to mention this the other day, and it's far from a Supercar. It was pretty decent for its time when it came out though - I spotted an old Mazda 626 coupe in mint, original spec during the week. It was the factory two-tone silver over blue with a red stripe, had factory alloys, etc. I'll post a link of what model it was when I jump on a PC.
A mate had one of these back in the day; it was such a nice handling car; really nice to drive.
When I was a 1st year apprentice one of my instructors had one with a 13B in it; now THAT was a nice car.
The driveline it should've had from the factory.
IIRC; the suspension is identical to S2/S3 RX7; but on a slightly longer wheelbase.
You're talking about the old RWD ones, Dale? I knew someone who had built a yellow one of those too, with 13b built by his brother, interior done by another brother (who did my interior retrim in the Stagea), and it was beautiful. Their attention to detail is incredible, they all take pride in their work.
The car I saw the other day was the first of the FWD ones, though.
Like this, with these factory alloys, etc., but no body kit:
Yep Nick, the RWD ones. :yes:
I'd forgotten about the FWD one; christ that bodykitted one is ugleh.
Always had nice interiors though.
  • 1 year later...
Hmmm...
Hadn't met Colin for 40yrs
Needless to say, we had some catching up to do at Jesus Racing's "Life In The Fast Lane".
Some people might know his son Adam Leung - Driving Instructor
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
