Yeah, it was a GTO. Well, it had the black rear cavallino, GTO badge and GTO wheels as well as a GTO number plate. Where did you snap your pic?
Friend on fb posted it so not sure where. But seems to be out and about quite often
Ok here we go
As Terry said, at about 1:00 it's really bizarre as there's this couple standing on the side of the road who have seen the Lambo go past and now the Ferrari, and they're pointing to my 12 year old Bimmer and saying they prefer that! Haha! :P
Edited by God_speed
Well what's a bit weird is if you watch the video again, when the 599 creeps past when still inside the valet area, the exhaust seems to 'blare' a bit, all of a sudden. Not sure if he just presses the sport button or whatever, I don't know what setup there is on the GTO (or Aventador) but it's possible there's a bimodal exhaust setup like the current Maseratis. So in normal running mode it'd be just under 90dB up to the test RPM, above that the valve would open. In sport mode the valve would always be open regardless of RPM?
I found this with an Aston Martin Vantage V12, but the opposite. Sit in neutral and give it a rev and you get creamy V12 goodness up until you get to 3000rpm, when something shuts off in the exhaust and it goes all quiet! I was like giving me a taste of the goodness, then not letting me have any more! Damm NVH engineers!
Ok here we go
I have to laugh at the 'innocent' bystander in this whole dramatic clip of...
* the Aventador
* the 599GTO
* the people on the footpath complimenting your bimmer; and that's...
the Disability Sticker hehe...
Nice sounds tho' in between city buildings :)
The SG9 '06-'08 model was riddled with the 1410 & 2432 fault codes Marko, where the air pump could deliver moist air into cylinder #1 > corrosion.
Fortunately mine was blanked off in time.
I think you should be happy with yours, for sure.
The SG9 has slightly better power/weight but Pulse Racing has a couple of tweaks that can help yours get along that much better.
The torque curve is steep on takeoff, but it runs out of puff pretty soon after.
Overall, the Foz XT is a very respectable 'sleeper' that shocks most V8s
Very happy with its reliability too with over 174xxxKms on my '06 model.
Are your rear seats a tad uncomfortable for long trips? If I see yours, I'd like to check out if I should update anytime soon.
I keep having 'arguments' with Nick about the XT being better than his Stag - haha
I've heard about this air pump and I think the series 3 has this as well? Does it run for about 30 seconds on cold start up and its purpose is to recycle the pollution back into the engine?
Yeah I've heard good things about pulse racing actually...bottom end and mid range is great and yes top end is not as strong due to the smallish turbo.
The rear seat is comfortable in fact...we should catch up as I'd like to see your n1 as well :) what part of Sydney do u live in? I'm inner west.
P.S. what is a stag? Not that old triumph thing haha
definitely is over 90DB - how do these exotic cars get away with this level of noise pollution?
harleys fall in the same category when it comes to noise...hmmm
First of all it isn't noise polution, it is noise orgasm.
2nd is stock standard factory ADR approved exhaust with valves.
3rd is there isn't a whole heap of them around where as in normal cars you can put a loud exhaust on any engine and it wil be annoying and every p plater will be doing happy laps around the streets for hours.
4th is it's a f**king V12, nuff said.
R35's are louder than 90db as well under full throttle, not just an exotic thing.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
