How Hard Is It To Build That Engine
DaGr81
 Share
You mean triple check, then get someone else to have a look. It's easy to miss something if you have been at it for hours!
Well worth it. I just haven't done an RB yet!
P.S I work on 4700 shaft horsepower turboprop engines at the moment.
  • Replies 46
Sean, my mate is about to take over as the Engineering Manager with Boeing up at Williamtown for the twin jet engine capability.
Now that is a world of hurt for technical integrity and triple checking........the whole aviation thing, and I won't touch it.
He and I studied engineering together as mature agers with trades behind us. We built holden V8 lumps, water skied and drank and perved on young girls and even got some study in.....
My machining work cost me 1400 for the 26/30 which included head skim, block work that was a skim, clean, full balance, full tolerance measure on every bearing in their intended location, crank plugs pulled and tapped and flushed and grubscrewed, welsh plugs pilled, collar fitted, tap high timing belt adjuster location, then (and this is the important bit) the block and head were given a full final clean so I didn't have to spend forever cleaning all the gunk out after the honing.
Like geoff said, but also have the main gallery end plugs removed and tapped for grubscrews also. You would be suprised as to how much gunk they pull out of the main oil gallery in the block.
If your real serious get it done for the head too. Normally all this is only done on race engines, so when it blows and you rebuild again its easier to just remove all the plugs and clean it all out.
I'm another vote for give it a go yourself if you want to learn. I'm no mechanic (anything but lol) but I've done 3 bottom ends now and only 1 ended in tears (and that may have been caused by a turbo anyway).
As long as the machine shop checks your piston to bore clearance, your piston to valve clearance (careful if the head and block have been faced more than once.....) and bearing clearances - the only thing left is the ring end gaps (you will need to file them down once the cylidners are prepared). Apart from that its just follow the manual and use a torque wrench.
Mate i rekon do it youself, like you said take your time, do it properly with ya mates help the feeling you'll get the first time it fires up will definately feel better than the burning pocket sensation from paying others to do what you can save the money for tuning :D
Hey guys!
Recently my 5th cylinder shat itself it had less then 50 compression
so it was decided that i was going to do a rebuild.
My brothers a second year mechanic and i've got pretty much no mechanical
knowledge at all. We're rebuilding it at my dads factory so theirs plently space
and we've got pretty much every tool!
Today just stripped everything and took the pistons and crank out ! (cylinder 5 oil ring was broken)
But yeah, i myself think that I've gained a fair amount of knowledge in a short time from just following
guidelines and watching what my brother does and just doing stuff myself ;) !
Most important thing i can think off is lining everything up correctly before disassembling everything.
That way it should be easy enough putting everything back together.
So far everything is going well but i know for a fact that i've saved alot of money ! :D
So yeah... i'm saying go for it :) Pretty fun too
ok so all this is going to have to be done slowly and in my own time etc etc, due to that if anyone could give me the names of a few good machine shops that will do the rb30 bottom end for me (the works honing and all that stuff) cheers. i'll see how it goes after i get it all machined up and ready.... should whether i try some of it myself or the whole lot will depend on how much im home (gaurantee that there will be a diy if i try it :)), will the rb30 block fit in my skyline to take to a machine shop lol? (gonna have to pull out the passengers and back seat me thinks....
Edited by DaGr81
question: will 1 shop (i.e. the one i decide to go to whateva it is) be able to do all the machining? like do they specialise or something or its just they do the whole lot? Also balancing...where is everyone getting their crank rods pistons and everything else balanced? What should i do to the crank shaft in order to get it nice and strong....
cheers to everyone who has made a positive input to this thread, everyones got their own opinions ofcourse but some people are just so negative... (i vote to move them to boostcruising.com)
also would it be wise to have the head done at the same time? dont really know what to brands i should go for to put into the head, ultimately looking for it to handle shifts at 7500-8000rpm without loosing bottom end power so something that carries right through the entire rev range, had a look at some of it, looks like its really technical when it comes to the head....what is everyone else with a built head running?
yes definately get the head checked out, and you will almost certainly get a nasty surprise. Every head I've had done has needed to be decked (surface flattened) new valve guides on at least the exhaust side, always new stem seals and a couple of times new springs. Normally costs as much as the whole bottom end :thumbsup:
But its better to do it all now than go with a dodgy head.
hmm, but what sort of valve springs and guides etc, which brands? theres some that are solid and some hydrolic what should i be going for? theres also some with more lift than others.... i might have to read up heaps on this
Above all mate!
If you are determined and passionate nothing will stand in your way!
No one is born with information!
You attain it!
Don't let no one tell you otherwise! :)
Very nicely said Nabil. Just do it. and dont worrie, when you fire her up for the first time its all worth it. E
pecialy when you go
for the first break in drive.
But thats also an important factor. The engine break in. So keep that in mind. You can build the engine perfectly but if you dont
break it in properly its all a waste of time.
 Share
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
    • Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst. I posted a link to them sometime in the last 2 weeks, I'm sure.
