yeah the break in period is fun :closedeyes:
If you are going Naturally aspirated, usually don't rev it too hard for the first 1000km, use a mineral based oil, good quality but definitely not synthetic
If you are going turbo, the easiest thing to do is just remove the wastegate actuator flap, so it's open, or the spring if it's external I think
after the break in, drain the oil and put a good synthetic in there :P then get a better tune and crank out the fun :no: 4th gear burnouts with vids FTW
Edited by skybarge
  • 3 months later...
  • Replies 46
My 2c..
Give it a go, if you have knowledgable help and the resources :/
My mechanic mate and I performed a twincam 30 conversion on my 32 in a weekend.. had a few teething problems but I did drive it home 3am Monday morning running rich as hell on the stock ecu :)
I got a prepped block, forgies and head off my mate and threw stock crank and rods in there and swapped everything off the RB20.. should have had the crank ground to begin with but you get that :) had to pull the engine out a month later and whack a new crank in it (only cost ~$300 for a new crank, machining and a set of bearings).
Now, Phase II: Birth of the GT35R is approaching :sick:
Cummon guys dont be so down. Go out and buy a good engine reconditioning book, and study it, bear in mind you will have to spend about $1000 on tools assuming you already have the simple tools like spanners and sockets, but youll spend that money on labour anyway. Get the motor machined up and assemble yourself, checking everything twice. Hire an engine crane for the weekend_or buy one, there like $200 on ebay) and swap them yourself, save you money and give you twice the satisfaction.
+1 with what Adriano said.
+2 with Adriano. Although i personally would get the engine built by a pro, and do the engine swap over myself. you will save atleast 1500 swapping the engine yourself and have peice of mind your engine was built by a pro.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
