hey all. I have to pull off the balancer from my RB30 bottom end and it is just a short motor. I rung an engine reconditioning place and they told me how they do it and I am not really keen on doing it till someone else says it will be OK.
they said a rattle gun will not have enough torque so forget that.
they told me to remove the sump and wedge a bit of wood between the crank and block then get a HUGE breaker bar on the balancer nut and apply a lot of force.
Will this possibly damage the crank? last thing I want is a bent crank...
sorry for the newb question :)
otherwise has anyone else got any ideas on how to remove the balancer from a short motor not installed in a car?
Hi CEF11E,
This is how i have done it before, and it doesnt damage the crank thats why you need to use wood as its softer than the crank so wont damage it.
I used a 3 foot breaker bar when i undid mine and it stil ltook alot of effort, and even then i needed to use a gear puller to remove it from the crank shaft.
hope this helps you
cheers
depends on how good your rattle gun is and air supply...
You should be able to do it with a normal breaker bar with 32mm socket i think from memory, if flywheel is on, use a screwdriver between teeth and the dowel on the block for the gbox. If no flywheel, put two bolts into the flywheel holes and put screwdriver between those two to hold the crank from turning while someone else undoes the crank bolt.
Then a puller to get the balancer off the crank.
27mm from memory.
the 'piece of wood between the crank and block' trick works well.
you arent wedging it on the main part of the crank, you're wedging it between the big counter-weights, and they are pretty meaty. you will not do any damage to it at all.
if u needed to remove the balancer with the motor in the car could you put the car in gear with handbrake on or will this damage gearbox?
to remove the bolt, get a breaker bar and have it lean over to the left hand side of the motor (right hand side if you're looking into your engine bay) so that it is levering on the ground.
then just crank the car and it will undo the bolt.
Yes, I believe that you are supposed to leave it in gear to undo it; alot easier this way too!
May get away with it this way with an rb30 balancer - I doubt it though as it will just slip the clutch. You can also remove the starter motor and jam the flywheel or drill a small hole through the bottom of the bellhousing and jam it that way.
lol you'd go to all of that trouble on a short motor when you could simple jam a block of wood in the crank somewhere?
Its seriously not that tight.
You just need a big breaker bar. :blink:
You just need a big breaker bar. :P
With a 1m piece of steel tube as an extension.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
