hey guys i was just wondering if the kkr turbos are any good this is the one i was looking at if its shit let me thanks guys:Trent
kkr430
Responsive turbo upgrade for br20 and
br25
Oil cooled,0.58 turbine housing suits t3
sized flange
Internal wastegate with 8psi actuator
Suitable for single turbo applications on
2.0 2.5 3.0 litre engines,or in twin turbo kits on
5.0 to 6.0 litre engines
comes with 71mm v-band section and v-
band dump pipe,t3 exhaust gasket,oil
inlet banjo bolt and oil return gasket.
RRP$849
Specifications for the kkr430core:
Compressor inlet pipe 69mm,compressor outlet pipe 50mm
48 trim compressor;inducer 53mm,exducer 76.5mm
Turbine wheel outlet 48mm,outer diameter 64.5mm
https://www.sau.com.au/forums/topic/183792-are-kkr-turbos-any-good/
kkr430
br25
sized flange
RRP$849
id go 430 for rb 20 and 480 for 25 (based on what i saw from the Forced Induction - Turbo upgrade threads).
Also the GT Autosound LS1 R34 is using twin KKR turbos.
Ive read they are German made...so it must be good :)
here is all the stuff on the kkr 480
Big power potential at a bargain price
Oil-cooled,0.84 turbine housing suits t3
size flange
internal wastegate with 8psi actuator
suitable for single-turbo applications on
2.5-4.0 litre engines,or in twin turbo kits
on 5.0 to 7.0 litre engines
v-band for dump pipe,t3 exhaust gasket,
oil inlet banjo bolt and oil return gasket
RRP$899
Specifications for kkr480core:
48 trim compressor;induser 53mm,exducer76.5mm
turbine wheel outlet 56mm,outer diameter 73mm
Ive read they are German made...so it must be good :P
I think you are thinking of the KKK turbochargers which are German.
These ones are chinese turbos, and they are crap to say the least.
Reported needs of fijity modifications to the dump pipe to fit it on the stock manifold, and because of these modifications the turbo could be put on with a bit of stress on one side of the mounts which will cause something to break. Also you have to watch out for the oil lines going to the turbo and find out if they have to be bigger or not... Sounds like a whole lot of stuffing around if you ask me or anyone else in forced induction.
Suit VL Commonwhores.
hahaha so what would be the best turbo for price and drifting out of all the turbos and could you give me a little bit of info on them because im researching and trying to get the best value for money and i dont want some crap chinese turbo that will blow up as soon as it hits the boost
to be honest, to be proper you would want to have about 2,500 bucks handy and set aside for doing it and have an EMU already.
I have a highflow turbo and its on the stock ecu and im getting, well i was getting 230kms per tank while driving. not exactly good economy. Tune it with a power fc or an emanage and expect it to feel much better and return good economy.
What turbo you ask? a Garrett or a HKS option would be good. I have heard nothing but good things about HKS GT-RS.
I have just installed a KKR430 turbo to my RB20. The bolt on really easy. I got the RB dump pipe to suit too, so that made life a little easier too. The only mods you have to do are the turbo outlet (not being the normal three bolt nissan, so it takes a silicone 90degree bend and a bit of intercooler piping to fix) the turbo inlet (I just cut down my standard intake pipe so it was big enough to fit) and a little bit of grinding on a bulbus fixing point for a bolt on the exhaust manifold. So all up it was a really easy fit!
Hey guys
Yeah i ran one on my Cefiro last year, good turbos for the price however without a tune/remap they are ultra laggy, as you would expect throwing a larger then stock turbo on without touching it. With a remap i picked up a fair wack of responce but i still had no power below 4000 rpm... above that it just took off.
Then on the 32 i fitted a Sliding highflow on my rb20, which i found to be better in terms of responce and power, not to mention ease of fit.
I now have a RB25 and stock turbo lol... but im more then happy with it atm (215 rwkw and loads of torque)
i had a kkr 430 on my rb25det. it was alright i thought. had no problem with it at all. but id go with the hks gt-rs aswell. heard very good feedback on them. and has a nice power curve. i think im going highmount on my next rb25. :thumbsup:
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
