Id say maybe a GT3071 in an external gate setup with some advance in timing thru some adjustable cam gears. soemone back me up on that?
IMO you should put something in the Forced Induction section of the site and they will give you a good answer or "WHY DIDNT U LOOK HERE" answer to which you will get a correct answer anyway.
Edited by Pauly33GTS-t
3071 to big for a rb20, i have a hks t3g (old skool) on my rb20 not too laggy n runa around the 210rwkw @ 14psi
best bang for buck softy would say hks 2530 i reckon or the garret 2871r
I said GT3071 because he had a Rb25... lol read man.
i think he wants response and power.
I've really only heard a few bad things about these turbos - Mainly good thing though. The bad was to do with a manufacturing problem with the W/G overboosting.
Seems like good value for the coin.
I'm thinking of one of these for my pig project as they are cheap.
I have a VL turbo turbo on the FJ at the moment - seems pretty small - the W/G is dodgy welded shut and has an external WG. So I'd be thinking of bypassing W/G on these one of these cheap turbos anyway.
I will see how the VLT turbo goes after we fix the dodgyness.
Or you could just get the GT3076R from Garrett (same as HKS GT3037). GT3071R (same as HKS GT2835, except only in T2 flange) would be good on the RB25, but would have to do some mods to make it fit the manifold... :P
GT3071R (same as HKS GT2835, except only in T2 flange) would be good on the RB25, but would have to do some mods to make it fit the manifold... :whistling:
what about machining it into a VG30 exhaust housing? My understanding is it'squite a bit bigger than a 25 one.
Would it limit power TOO much? Be nice and responsive id imagine?
Im thinking of doing this for my RB20DET, but with a GT2871, into a RB25 exhaust housing (Already have RB25 turbo on car)
As for KKR, Only MAJOR drama Ive heard is they've had WG problems, and as Simon said, you'd need cams and tuning to make the most of it.
Is getting the stock turbo Highflowed an option?
Edited by R31 drift pig
ya get what ya pay for in this world.
A friend has one on her SR, its got top end ( not too much0, but pretty laggy. I would say the standard SR turbo would be overall better than the KKR.
My 2 cents lol
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
