Hey u goin guys planning on takin my skyline back 2 calder this fridai nite went last time with 3"inch turbo back and front mount air filter ( no heat shield or cold air induction) and a boost controller not EBC ran a 14.3 at 100.2 MPH now i dont know if thats shit or decent or wat for a r33 series 2 was hittin around 9-10psi , now ive got a greddy profec B spec II in and a full 90mm cold air innduction ran should i b looking for better times? if so roughly wat with decent take off and gear changes
https://www.sau.com.au/forums/topic/183800-14-mile-return/
what was your 60' time?
aroun 2.0 is good, 2.2 is average and can be improved upon.
without sounding slack, 14.3 is not a good time.
9-10 psi in a stock ECU'd r33 means it would be running pretty rich and on the edge of misfiring and carrying on.
cheapest way to get better times (apart from practice) is a tune with an SAFC to fix the air:fuel mixtures.
obviously some street legal drag radials.
then practice away.
maybe list any other mods.
what:
wheels and tyres and what size are they
what tyre pressure?
clutch
do you know what power it is making?
https://www.sau.com.au/forums/topic/183800-14-mile-return/#findComment-3328903
Hmm thinkn runnin back 2 standard boost on the nite , dunn have a clue power havnt had it tuned or dyno'd standard 16"inch wheels and standard clutch...like it hits around 7 then the boost slowly creeps up 2 around 9 on higher revs
2.303 60"
tyre pressure was around 28 psi for the nite from memory
https://www.sau.com.au/forums/topic/183800-14-mile-return/#findComment-3328912
just to give you a rough idea, my younger bro has a r33 gts-t series 1.5, stock turbo and engine, stock ecu (no SAFC), boost at 12psi, full exhaust, FMIC and a pod, pulled a 13.3 with a 2.0 60 foot time.
You should easily crack a high 13 with you mods if you launch it right and drive it hard.
https://www.sau.com.au/forums/topic/183800-14-mile-return/#findComment-3329349
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
