im having fun with this car.. just ordered a TD05 and PFC and now more problems happen..
driving along(car is a Type M R32 GTST btw), and was at the lights.. in first, took off normally, jumped into second and the car started jumping. didnt hear any crunching or weird noises from box/clutch, more like it was ECU?
basically, its like ive lost all boost!
i would get to 2500-3500 before the car would jump and idle weird... normal idle went from 700 to about 1300rpm... i would have to go from first to second, and stay below 2500rpm to be able to drive it back..
any ideas what this could be? :S i want this fixed before GOR!!
its a standard Type M R32 manual gearbox, wtih nismo short shifter.. thats it... only other mod ive done recently was front mount but i checked the piping and it all seems alright?
https://www.sau.com.au/forums/topic/183807-not-again/
Check under the oil cap to see if the oil is milky.
Also check the water in the radiator to see if its oily.
Check the dipstick also, see how the oil level is, and how good the oil looks.
Is it over heating at all?
Edited by abu
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3329701
the first set of issues sounds just like AFM... could be dirty or need resoldering. if you have someone with the same one, borrow to test, else search the forum for +solder +AFM. i just did mine its not hard.
bubbles in the radiator liquid could just be some air escaping the system.. did you replace your coolant recently ? does the car lose water ?
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3329771
Maybe fuel pump? This happened in my r33 and it was the fuel pump.
Don't think a dying fuel pump will make too much variance on idle. In my past experience a dying fuel pump makes the car slightly hard to start, hesitates in the rev range and also pings if its turbo.
The more you think about it, the more it sounds like an AFM issue.
Abu
Edited by abu
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3330486
time to have a little play right now.. i hope it is AFM... we are going to clean the air flow metre, and check all hoses and piping... if its a dodgy afm, no loss, im getting a Z32 :P ive been persuaded that its air flow metre/piping so ill see how it goes and get back to you :D
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3331039
  • 1 month later...
hey, i had the same problem with my r33 s2,
after i just got my apexi neo afc fitted, 2 days after it did the same thing as u described!!!
i had to reset the afc to drive..and it was fine..
went to the tuners 2 days later, found out my 02 sensor was dying, or dead already..lol
needed a new one..and has bein fine ever since...
so try disconnecting the 02 sensor..
and c if it makes a difference..
but i think my afm is on its way out having trouble starting wen cold..bein cold latly for the last 2 days, and my car struggles only wen very cold..i think either to do wit my afm, or im to lean for idle..lol
but i cleaned my acc valve the other week..look lik brand new inside..and idle has bein really really good..
i cleaned my afm, wit electical contact cleaner,looks cleaner
and i cleaned my acc valve wit carby cleaner..and keep on wiping in it! takes a while..but makes a hell of a diff.!!
so try doing these, and check ur o2 sensor too...
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3442846
just checked the radiator while car was on (car now sits there and idles from 700, and slowly SLOWLY VERY SLOWLY goes up and sits on 2000rpm), and there are bubbles?
gasket? :P
This exact same thing happened to me on sunday night. I had just put a 3" cat back on and was going for a spin (my pc had just broken to zzz)and the car started stalling and playing up so i pulled over and fiddled with the AFM wires until the idle returned to normal (i had just put on pod filters) i also had what looked like froth coming out of the radiator (as opposed to bubbles) but the car wasn't overheating and was dead on center
Only problem with mine is now it's making a noise (not overly loud, probably about as loud as the injectors but a bit less harsh), screw driver indicates it's coming from the head, so idk what happened but i'm guessing when the AFM frigged up it over stressed something and something broke or was badly worn (it still drives ok)
Just my luck, 5 days till i can finally drive it and it farks up along with the pc and the job i quit on friday ._.
Edited by GTAAAH
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3443012
Thats your car going into R&R mode (limp mode) so you can drive it home without detonating the engine. You'll need to reset the ECU and do a self-test diagnostic, this will tell u whats broken i.e. as above 02 sensor etc.
I believe :P
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3443393
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
