im having fun with this car.. just ordered a TD05 and PFC and now more problems happen..
driving along(car is a Type M R32 GTST btw), and was at the lights.. in first, took off normally, jumped into second and the car started jumping. didnt hear any crunching or weird noises from box/clutch, more like it was ECU?
basically, its like ive lost all boost!
i would get to 2500-3500 before the car would jump and idle weird... normal idle went from 700 to about 1300rpm... i would have to go from first to second, and stay below 2500rpm to be able to drive it back..
any ideas what this could be? :S i want this fixed before GOR!!
its a standard Type M R32 manual gearbox, wtih nismo short shifter.. thats it... only other mod ive done recently was front mount but i checked the piping and it all seems alright?
https://www.sau.com.au/forums/topic/183807-not-again/
Check under the oil cap to see if the oil is milky.
Also check the water in the radiator to see if its oily.
Check the dipstick also, see how the oil level is, and how good the oil looks.
Is it over heating at all?
Edited by abu
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3329701
the first set of issues sounds just like AFM... could be dirty or need resoldering. if you have someone with the same one, borrow to test, else search the forum for +solder +AFM. i just did mine its not hard.
bubbles in the radiator liquid could just be some air escaping the system.. did you replace your coolant recently ? does the car lose water ?
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3329771
Maybe fuel pump? This happened in my r33 and it was the fuel pump.
Don't think a dying fuel pump will make too much variance on idle. In my past experience a dying fuel pump makes the car slightly hard to start, hesitates in the rev range and also pings if its turbo.
The more you think about it, the more it sounds like an AFM issue.
Abu
Edited by abu
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3330486
time to have a little play right now.. i hope it is AFM... we are going to clean the air flow metre, and check all hoses and piping... if its a dodgy afm, no loss, im getting a Z32 :P ive been persuaded that its air flow metre/piping so ill see how it goes and get back to you :D
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3331039
  • 1 month later...
hey, i had the same problem with my r33 s2,
after i just got my apexi neo afc fitted, 2 days after it did the same thing as u described!!!
i had to reset the afc to drive..and it was fine..
went to the tuners 2 days later, found out my 02 sensor was dying, or dead already..lol
needed a new one..and has bein fine ever since...
so try disconnecting the 02 sensor..
and c if it makes a difference..
but i think my afm is on its way out having trouble starting wen cold..bein cold latly for the last 2 days, and my car struggles only wen very cold..i think either to do wit my afm, or im to lean for idle..lol
but i cleaned my acc valve the other week..look lik brand new inside..and idle has bein really really good..
i cleaned my afm, wit electical contact cleaner,looks cleaner
and i cleaned my acc valve wit carby cleaner..and keep on wiping in it! takes a while..but makes a hell of a diff.!!
so try doing these, and check ur o2 sensor too...
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3442846
just checked the radiator while car was on (car now sits there and idles from 700, and slowly SLOWLY VERY SLOWLY goes up and sits on 2000rpm), and there are bubbles?
gasket? :P
This exact same thing happened to me on sunday night. I had just put a 3" cat back on and was going for a spin (my pc had just broken to zzz)and the car started stalling and playing up so i pulled over and fiddled with the AFM wires until the idle returned to normal (i had just put on pod filters) i also had what looked like froth coming out of the radiator (as opposed to bubbles) but the car wasn't overheating and was dead on center
Only problem with mine is now it's making a noise (not overly loud, probably about as loud as the injectors but a bit less harsh), screw driver indicates it's coming from the head, so idk what happened but i'm guessing when the AFM frigged up it over stressed something and something broke or was badly worn (it still drives ok)
Just my luck, 5 days till i can finally drive it and it farks up along with the pc and the job i quit on friday ._.
Edited by GTAAAH
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3443012
Thats your car going into R&R mode (limp mode) so you can drive it home without detonating the engine. You'll need to reset the ECU and do a self-test diagnostic, this will tell u whats broken i.e. as above 02 sensor etc.
I believe :P
https://www.sau.com.au/forums/topic/183807-not-again/#findComment-3443393
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
