G'day!
Ok, with my R33 - Ive got the full Sydneykid set up plus a hicas lockbar
Currenty with my sway bars, the front is on "medium" and the rear is on "hard"
If I put the rear to medium, how much difference will it make?
Less "oversteer"?
I guess for this event I dont want to get too much oversteer (even though it is fun!!)
Should I leave the front on medium setting?
When I did DECA last, I didnt have too much understeer on the skid pan which was good, but was still getting a bit too much sideways and losing some time
any ideas,thoughts, comments are welcome!
cheers,
Chris
https://www.sau.com.au/forums/topic/183873-sway-bars-for-motokhanaautocross/
Yes, softening the rear bar will have less oversteer. I've found that the settings on the rear bar make quite a bit of difference, more noticable than changes on the front bar too. Which makes sense as the lever arms are longer on the front to rear, but the holes are the same difference apart. So the percentage change in effective lever arm length is bigger on the rear.
Edited by salad
I have same setup as you evil... I always run the front on medium and just play with the setup on the rear... full hard on the rear was the most fun and made it more responsive as 33's with the heavy rb up front and the long wheelbase tend to push understeer really badly on the skidpan...
buuuuut that being said it is much more balanced/nuetral with the rear bar on medium... and if you are pretty agressive with the handbrake when required you won't see any understeer... this is now my preferred setup
this is all pointless anyway when you consider the stock diffs multiple personalities... harder the rear bar is the more single spinning you get
i found even with the front on medium and the rear on hard it was still a bit understeery, i changed the front to soft and it feels great, pretty oversteery which id assume would be the best balance for autocross. thats what works best for me and thats with a r32.
Just an update...
took the car with the sway bars both set to medium to our texikhana
did a wet skid pan (on semi's...... :happy: ) was sucked
however on the back track the car felt great!
Ive done a few road type events before at DECA and the car yesterday, just felt nicer and balanced all over - with my semi's on I hard hardley any oversteer, and if it did it was because getting on the gas too early but when it did, it didnt throw out as much as it did before! and had no understeer!
so was really happy with the set up - thanks again Nick for the tips
  • 5 months later...
bump :thumbsup:
More questions on sway bars guys :D
I did a day at wakie yesterday (first time and managed a 1.14) and I had my sway bars changed to both on maximum hard. during the day, I was getting a bit understeerie, and also I started open wheeling on some tight turns (fish hook and last turn)
what are peoples thoughts if I changed both to medium for track work (not khana's?)
or medium rear, soft front?
Has anyone changed sway bars to any and many combinations? If so, what were they?
Prevoulsy in this thread I had them on mediiums for one day, worked well. Just wanna see/hear others thoughts.
Gary??? :D
From me experiance with recently setting up the GTR you better off setting the bars to close to the fatcory spec firstly. Medium probably in your case. I actually went back to factory bars initially.
From there I focused on getting the tire to work properly, buy a pyrometer or at least an infa red thermometer and check tread temps after a session. Set up the allignment so the tire is working to its potential then use the sway bars.
I went out firstly with an alligment I thought would be good but found it to need much more camber and a little more toe out to get the tires working properly.
I found after getting my alligment to a position I was semi happy I was left with minimal understeer. I left the front bar in the center of its adjustment and slid the rear till the understeer was less apparent. I dont have hole type adjustment Im using slide types.
Edited by Risking
Cheers Brad,
Yeah druncan said the same, get one of thse heat things onto the tyres after a session and record/measure the temp for my settings.
Im gonna put them back to medium for this sat and see how the nugget goes!
You doing the tampered day then?
If you set the front to medium and leave the rear at hard it will improve the understeer.
I'd be inclined to go soft front/medium rear until you get a diff to try and work around the open wheeling issue.
I usually start of with the front bar on full soft and the rear on the middle setting.
If it oversteers too much, then I move the front bar to the middle setting
If it still oversteers too much, then I back the rear bar off to the softest setting
If it still oversteers too much, then I move the front bar to the highest setting
If it still oversteers too much, then you might need some more rear camber and/or the HICAS is still working (get rid of it) and/or the rear subframe alignment kit needs to be set to maximum traction (squat)
OR
If it understeers too much, then I move the rear bar to the highest setting
If it still understeers too much then you don't have enough caster/camber on the front
Cheers
Gary
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
    • Yep, agree with all of the above added on too. I just love the age old "what boost were you running?" Question without getting any other surrounding data. IE, may have ran 20psi, and lived for 12 years, but it was an 80 year old granma driving it to Bingo once a week and never took it over 2500rpm.
