D-day 2007 - The Ultimate Dyno Showdown Ft. Dj Matt Ferreira
Hey All,
This ultimate D-Day dyno challenge will be a day not too miss... We will play host to some of Sydney's most insanely modified street cars and drag weapons... With one of Sydneys most prominant and renowned house Dj's Matt Ferreira laying down a set during the day while you enjoy the dyno shoot out, bbq and show and shine of some of Sydneys top modified cars you are surely not going to be disapointed.
Time and Place Date: Saturday, September 22, 2007
Time: 9:00am - 7:00pm
Street: 39 Rookwood Rd
City/Town: Greenacre NSW 2190
Country: Australia
With DRC housing a Mainline 4WD Dyno - AWD1000 we are able to take entry's from a wide variety of high performance and street sleeper weapons with prizes and trophies for the winners of each class.
Entry Classes:
- 4 Clynder/Turbo
- 6 Clynder/Turbo
- V8/Turbo
- 4WD/Turbo
- Rotary/Turbo
A professional photographer will be there on the day to snap pictures of your pride and joy on the day to remember the event!
All expressions of interest should be forwarded to: [email protected] so that we can confirm numbers for the day and ensure the event runs smoothly.
Thanks,
Team DRC & T4S
241rwkw@18-19psi Woot!
for $40 it was a bargain for me.. in and out in less then 15minutes HAHAAHHA arrived around 5ish.. empty about to close actually.
Since my last 3 different dyno runs(220-228rwkw) i've added:
-Gasket for GTR Bov , didn't have one before
-Silicon Intake Pipe from Bass Junky's Group buy
-E-clip on turbo actuator (missing before)
Boost now holds all the way to redline with an Apexi Avc-r + Gtr bov. now time to head to the drag strip and see if my MPH increase to show if i really did gain 15-20rwkw LOL!
i was driving past at arround 2ish and seen our own presidente's car.so i decided to pull in and see what was going down.vic and blitz were also there.sorry i cant remember your name :P.there were a few nice car's that turned up.in my 10 mins of being there.ferrari,supercharged clubby etc.
nice clean place.with some nice cars.
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
