  FineLine said:
If thats the case i guess brocky must have been a real tryhard. :nyaanyaa:
... please u knw what i mean.. just proving ur own ignorance.. look like a wanker anymore riceboy..?
  KnoTT said:
AWD + Water = funny shite, last night was interesting, i proved your theory wrong Noel :) they do get sideways
yes they do.. tried a 6000rpm launch in the wet in one of them yet..!!! i remember doin that once.. scared the shit out of my mate following..
https://www.sau.com.au/forums/topic/183906-hey-hey/page/2/#findComment-3333464
  Oblivion said:
bahaha you have the SR wont you break a rocker arm before too long :)
jk
thats funny.. his SR is stronger than ur RB20 its closer to being a GTR than a GTST really.. Solid lifters. 87mm pistons bigger oil pump similar to a N1.. the GTiR engine was the GTR or SR..
and a set of RAS will fix that.. i fitted some yesterday on a VCT SR.. stupid having to angle grind the rocker cover to miss the VCT gear oil shield.
https://www.sau.com.au/forums/topic/183906-hey-hey/page/2/#findComment-3334947
Ok, well seeing as im welcome here, heres some pics for those of you that havent seen it in the flesh, or should i say metal, or plastic, what ever it wants to be!
The AVC-R is now on the dash where I can get to it easier, and the coffee stain on the drivers seat is gone haha
Edited by KnoTT
https://www.sau.com.au/forums/topic/183906-hey-hey/page/2/#findComment-3335130
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
