yeah afm surging is a known issue when the afm is close to such a large compressor inlet
put a bend in the pipe work between the afm and the compressor inlet, that should sort it out
or make long and a bend
hey guys
I been re-tuning my car in the lasst couple of weeks.. long story why it needed a re-tune but i started to do it with the Hand Controller as i dont own the PFC adapter myself.
Anyway i found this issue appeared on my car!! I ended up finding out (after a long time muckin around) that my TPS was set incorrectly. It took me 3 goes to get it right.
How i did it was losened off the 2 phillips head screws and then moved the tps untill i heard it click. then held it there and tested the throttle - the idea is to have the throttle move as little as possible before the tps clicks.
The way i got it was made it click and then moved it very slightly as well before doing the screws back up and that fixed the problem for me.
Although my engine was leaning off bad when it was missing like that.
Hope this helps
Finaly got round to going over more,
Fitted my tomei pump and ensured the correct 300kph at idle with no vac
Lengthened the intake by almost half a meter and put in 2 90deg bends, no change, also tried with no filter, and a spare maf.
Cleaned out the CAS that was nasty, still no change
set TPS all over the place, no change, though i didnt notice the click? S1's click as well?
Threw new plugs in with .85mm gap, yep, no change....
Pulled the fuel rail off the head, no leaks, no dribbles, all the testing all the bottles were evenly filled,
Compression tested it, 155psi +/- 3 psi for all.
I then sat long and hard and thought, I only realy noticed the slight miss after i fitted the gizzmo launch controler, I think it might be making problems, going to un-solder the wires and use 6 pin electrical connectors so i can remove and re-install it easy...
Edited by Rezlo
I have now gone over everything electrical, nothing has changed, i have fcked with every setting in the pfc, no change, full re-set on the pfc, no change.
its amazing how my 1975 Datsun 1200 runs better.
I have 2 suspicions, either my coils might be the source of the problem, or it is because of the large size of the q45 throttle body. Very little throttle percentage lets in large amounts of air into the plenum and Im suspecting the pfc doesnt let go of the "idle" mode.
It could be this that agrivates it, but I think it could be my splitfires failing, I only noticed it start doing the miss about 2 weeks after fitting a gizmo launch controler, which I have now removed and it still runs with a slight miss.
I am going to try stock coil packs out of another S1 I have tonight and see if there is any change.
Besides testing ohm's between + and - on the coils, what other testing specs are there on the ignitor and coil packs? want to get to the bottom of this problem, did a search but all i found was people wrapping them up.
I had a very similar problem on my all-but stock R33. I would be driving at very low throttle through say a car park and the rev would drop JUST below the minimum needed not to stall. This would happen at lights too while trying to sedately take off. Very annoying. My mechanic only found it by bashing my TPS with a hammer (he was getting desperate lol) while the car was idling - the voltages went berko and all over the place. He said they looked fine while just measuring them normally, but a bit of stress or a bump or whatever and it was game over. Might be that. Get violent :)
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
