  • Replies 187
Posted Images
I*ts still fighting, Longest labor pains i ever saw. mick the magician is working through the bugs one by one.
Couldnt get it to rev past 4500 initially. Brand new plugs were cracked, one completely broke when we pulled it out.
Fixed that. got it running, dosed it to 5000 rpm and it went spastic, 30 lb of boost and mass power. WTF. Seems some clown hooked up the wastegate incorrectly. :P:no::P:( I think the cat did it. ;) Fixed that and started real time tuning. almost there with the run in tune. Had to turn it off because of the noise curfew. Still way rich, no timing, low boost at 6900 rpm making 296 hp atw.
Gonna finish the run in tune tomorrow morning. gotta love micks final shot before the night. "f**k this thing is gonna make some fat when we start power tuning" hmmmmm, Aint that what we built it for. :laughing-smiley-014:
whats low boost noel? fk me 30lb boost, wheelspin tyre smoke and flamage out the back end?? haha make sure you post that chart up noel or atleast shane n e way.
Low boost will be 18 lb for daily and 25 lb for hipo Adam. thats what it was built for and it will do it all day long unless i am mistaken. It has all the gear to do it and do it safely.
The engine has a good feel to it. I think its a winner. I am going to predict somewhere around the 375/380 rwkw on hi boost. :whistling:
I just blew, shit myself and em having the tantric moment atm.....
one word.
FARKENHELLIJUSTWANTONE!!!
Edited by Oblivion
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
