  • Replies 187
Posted Images
I*ts still fighting, Longest labor pains i ever saw. mick the magician is working through the bugs one by one.
Couldnt get it to rev past 4500 initially. Brand new plugs were cracked, one completely broke when we pulled it out.
Fixed that. got it running, dosed it to 5000 rpm and it went spastic, 30 lb of boost and mass power. WTF. Seems some clown hooked up the wastegate incorrectly. :P:no::P:( I think the cat did it. ;) Fixed that and started real time tuning. almost there with the run in tune. Had to turn it off because of the noise curfew. Still way rich, no timing, low boost at 6900 rpm making 296 hp atw.
Gonna finish the run in tune tomorrow morning. gotta love micks final shot before the night. "f**k this thing is gonna make some fat when we start power tuning" hmmmmm, Aint that what we built it for. :laughing-smiley-014:
whats low boost noel? fk me 30lb boost, wheelspin tyre smoke and flamage out the back end?? haha make sure you post that chart up noel or atleast shane n e way.
Low boost will be 18 lb for daily and 25 lb for hipo Adam. thats what it was built for and it will do it all day long unless i am mistaken. It has all the gear to do it and do it safely.
The engine has a good feel to it. I think its a winner. I am going to predict somewhere around the 375/380 rwkw on hi boost. :whistling:
I just blew, shit myself and em having the tantric moment atm.....
one word.
FARKENHELLIJUSTWANTONE!!!
Edited by Oblivion
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
