  • Replies 187
Posted Images
nuthin yet, i drove by after work and its strapped to the dyno but he wasnt there. too busy to get exited atm so its probably a good thing. if i was sitting at home waiting for it i would be tying myself in knots.
Hoping for a result tomorrow tho.
better call me as soon as u hear the result
side note: rang michael this arvo, he was with the car getting it tuned, it'd already pulled 587bhp on 24psi, they hadnt even touched the cams yet or setup the boost controller lol. he also said it was making 20psi @ 4000rpm, and full boost by 4200rpm. all hail the rb30 :)
Info I got from george is 597 hp, boost at 4400 and the tuner hasnt touched the cams, still on zero.. WTF!
Surely there has to be more in there somewhere. For a track car i would thing they would be looking to bring the boost on a bit sooner. Methinx that engine is going to need some time on the rollers to unlock its full potential.
shane was talking about our car which started getting tuned yesterday arvo at mercury.
*removed the details* Safe to say big power!
I never thought i would say this, but i dont think i want anymore power now, maybe just abit more response if that can be achieved with the cams :) 4 straps on the dyno just to keep it from wheelspinning, it was pretty scary and insane to watch it kick sideways on the rollers constantly.
sorry to hijack your thread noel, so hows your beast coming along? Anyword?
Edited by r33_racer
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
