3 Genuine Gibson Motorsport Hr31 Skylines At Sandown Raceway
Big boy, Brisby and Patric
I'll be there at 9am tomorrow but just give me a yell when you get there and i'll come out with the tickets. My number 0423 856 410.
There are some mean machines this year, there is one that probably your fav Mr Brisby, a fully race pre Audi.
Apparently one of the R31s crashed?
Must happened at race 3 on Suday arvo then, i heard the 31 won the first race on Sat, i saw second race early sunday's arvo and the Ford Siera won, didnt' hang around to see the last race.
Yeah both the R31 and Sierra "disappeared" in the final race on Sunday. We couldn't see what happened to either from our vantage point - was down turn 1 way for both. But they were both just there one lap and not the next.
R31 Broke a diff or CV, Pulled off the track and was towed back, Sierra was bumped off the track by the RE car VC commodore that was in the top 3.
Gavin started to get a feel for the GT-R and ended coming 2nd by about 2 metre's to the commodore but it was a great race to watch.
In that shot of the DR30, the guy behind the wheel is Tony Scott.
He's the guy who put that very car on pole at Bathurst.
What year was that? 1986?
Hooks
Was he also the co-driver with Fury in 84 when Fury had that famous lap and stuck the bluebird on pole?
Gary Scott, to me it felt like I was surrounded by royality, jim richards, graeme "jackie" stuart and gary scott. Did anyone see fred gibson on the weekend was he flating around?
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
