hey PRANK,
you said u were installing the HKs type1, ..im gonna be doing that 2moro..
i heard that it removes the 180 speed limit... becuase u gotta hook the brown and blue wires into the ECU, which are speed and rpm..
so it loops the speedo thru the TT and removes the 180 limit..
any truth in this???
mc
:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/3/#findComment-36646
  • Replies 57
saiyan : thast what i asked..i believe it does..
firends of mine say they have gone over 180..and are using the type 1..
but they are running different that stock wheels..
and didnt push more than 190..
so i dunno
im a bit warey of trying it out (over 180) after i get my type1 fitted..
mc
:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/3/#findComment-37229
I've made my appointment for BRANT installation this Saturday 3rd August 9AM. If anyone else is interested, there will be a $60 discount for a AA02A or a $100 discount for a nemesis alarm if you install one at the same time.
In North Sydney area. Msg me ASAP or email: [email protected]
https://www.sau.com.au/forums/topic/1840-brant/page/3/#findComment-37384
Nemesis 2 wont be available until late in the year - it will have full
onboard monitored GPS tracking and will cost approx $ 2600.Nemesis 1 is
available now and will be upgradeable to the tracking when it is
available. Nemesis 1 costs $ 990.
Nemesis 1 is $ 990 fully fitted. Only options are power window lifter
modules which are $ 95 fitted for 2 windows or $125 fitted for 4
windows.
At this stage we are still tossing up between three carriers for our
tracking but wld estimate that the tracking would cost around $1700 to
$1900 if we go fully monitored 24/7 or around $ 1200 if self monitored
via mobile phone.
As stated we have no firm date yet on Nemesis 2. Nemesis 1 is also
compatible with any other tracking system provided the Nemesis is fitted
first ( as tracking systems wld use Nemesis remote to operate their
system)
https://www.sau.com.au/forums/topic/1840-brant/page/3/#findComment-38481
Guest | hype^ |
windows.
WTF!!! i just got a quote for the window lifting with a AA02A today and they said itll be 160$ extra!!
wats up with that!!???
https://www.sau.com.au/forums/topic/1840-brant/page/3/#findComment-46482
I have had a AA02 fitted to my car (since removed) and the only thing I could complain about is not so much the "range", but the time taken to arm and disarm etc.
I now have a quik trak installed and very shortly this too will be removed and replaced with an even better system in about a month.
I am not saying either of these systems are bad, or failed in anyway - but I take vehicle security quite seriously and get to test out and try new systems when they are released and updated etc,
https://www.sau.com.au/forums/topic/1840-brant/page/3/#findComment-47847
I will be selling the Quik Trak when the other system gets installed.
I have alreay been offered $750 for it, so I'll see what happens..
Can't say too much - but it will be Sattelite based, and not Tower based like QT. (nOt that that is a problem for me in the sydney Metro area, I just want to get a sattelite system and this new model will be available soon ( final testing phase)
If this new system is as good as they say - I will try and arrange for some special skylinesaustralia and performance forums members prices etc. - Stay Turned..
https://www.sau.com.au/forums/topic/1840-brant/page/3/#findComment-49533
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
