its easy take you stock one off fit up the adapter so you can plug your fuel hose straight into your fuel rail. then put your fuel reg in between the fuel rail and the old fuel hose. then leave the vac hose off and adjust the fuel pressure on idle to 42psi i think just trippple check on here, plug in the vac line and your done.
i dont have a clue where it is do u have any pics to guide me thru it plz sinistagtst?
look on the end of your fuel rail closest to the radiator, theres a branz coloured thing there held on with 2 screws thats your stock fuel pressure reg
OK thankyou sinista
