I'm not sure if this has been asked before but I didn't get what i needed to know when i used the search..
my oil pressure goes to about 7kg when cold.. and when its warm it drops to about 4.. i know that is normal as it has always been like that..
now.. after i had an oil change .. motul 8100... while driving the oil would drop to 2.. and when i rev it goes to about 3 or 3.5 but on constant speed is 2 .. (usually 4) and at idle its about 1.5.
but when i turn off the engine and start it again... it goes back to normal.. as in .. idle at 2 , constant speed at 4.. n revving makes it goes to about 5-6..
what is wrong with it?? is it just the oil playing up or theres more to it?
https://www.sau.com.au/forums/topic/184011-oil-pressure/
i understand ... more load means more pressure ...
but mine sometimes idle at 1kg and at constant speed is around 2kg.. that is abit low... since I've driven this car for almost 3years now and it was never like this before. and when i turn off the engine .. and start again.. it goes back to idling at 3kg instantly.. and while driving at constant speed is about 4kg ..
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-3336341
Hey all, my R33, 96MDL does the same thing, when driving around town its like 3-4 and when idleing its newere between 2-1.5. I used cheaper oils before and have now gone to Mobil1 10-30.. Maybe try changing oil back to 15-50, Maybe its common in sum skylines, either dodge gauge or lazy oil pump, Plz let me know how you go as mine is the same. Cheers
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-3336401
  • 2 years later...
My r33 SI allso same. i just change the oil with motul 8100. b4 i use 0-40 castrol edge. when cold start with 0-40 it goes to 6-7-8.
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-5061363
there is some very good forums on here regarding what oil to use..everyone should read them.
as far as using 0-40 vis for 25det...i wouldn't
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-5062279
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
