I'm not sure if this has been asked before but I didn't get what i needed to know when i used the search..
my oil pressure goes to about 7kg when cold.. and when its warm it drops to about 4.. i know that is normal as it has always been like that..
now.. after i had an oil change .. motul 8100... while driving the oil would drop to 2.. and when i rev it goes to about 3 or 3.5 but on constant speed is 2 .. (usually 4) and at idle its about 1.5.
but when i turn off the engine and start it again... it goes back to normal.. as in .. idle at 2 , constant speed at 4.. n revving makes it goes to about 5-6..
what is wrong with it?? is it just the oil playing up or theres more to it?
https://www.sau.com.au/forums/topic/184011-oil-pressure/
i understand ... more load means more pressure ...
but mine sometimes idle at 1kg and at constant speed is around 2kg.. that is abit low... since I've driven this car for almost 3years now and it was never like this before. and when i turn off the engine .. and start again.. it goes back to idling at 3kg instantly.. and while driving at constant speed is about 4kg ..
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-3336341
Hey all, my R33, 96MDL does the same thing, when driving around town its like 3-4 and when idleing its newere between 2-1.5. I used cheaper oils before and have now gone to Mobil1 10-30.. Maybe try changing oil back to 15-50, Maybe its common in sum skylines, either dodge gauge or lazy oil pump, Plz let me know how you go as mine is the same. Cheers
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-3336401
  • 2 years later...
My r33 SI allso same. i just change the oil with motul 8100. b4 i use 0-40 castrol edge. when cold start with 0-40 it goes to 6-7-8.
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-5061363
there is some very good forums on here regarding what oil to use..everyone should read them.
as far as using 0-40 vis for 25det...i wouldn't
https://www.sau.com.au/forums/topic/184011-oil-pressure/#findComment-5062279
    • And at over $2 per litre I'm starting to consider setting up a corn mash still and converting over to alcohol and running mine on it !  Up side of that is it all doesn't have to go into the car ! Win win !
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
