as the title says, i changed from 17x7.5 all round to 19x8.5 and 19x9.5 rear
no scrubbing which is good but car is like a 4wd now lol, just gotta lower it 1 inch but what ive noticed is that it follows grooves in the road now, why is that??
is it just how it is, or i have some worn bushes which are made more noticeable with the bigger wheels
what he said plus the lower profile tyres are generally of a more square shouldered design so they bounce off the edges of the ruts left by traffic and wander back in to the trough. You will get used to it.
further to what they've already said, changing rim width and offset also changes your scrub radius, which has an effect on straight line stabilty. you may notice that tramlining effect gets worse under hard braking.
yeah. the scrub radious of the front end is all out of wack. get used to it or get wheels with the corect offset.
or you might just need a wheel alignment. low profile tyres show up dodgy alignments very hard.
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
