Hmmm, as above, I've got two questions for those in the know...
1. I'm getting a Bosch 044 in a few weeks time to replace my dying standard pump, and I'm wondering how hard/easy it is to mount it in the tank, and what I would require to put it in and wire up a nice fat power feed; and
2. I still haven't bothered to wire up my gauges, basically because I haven't yet found a good place to feed the wires through the firewall. Can anyone suggest a spot (or two) in particular? I've got the boost, oil pressure and oil temp sensors on the intake (driver's) side of the bay, and exhaust temp sensor feed on the other side.
Thanks in advance!
https://www.sau.com.au/forums/topic/184060-two-questions/
i hope the zip ties are resistant to petrol.....i say clamps FTW
what power outputs are you looking for nick.
the bosch 984 has a hose end on the bottom, is shorter than the 044 and flows a bit more than an 040.
the 044 is a little tight in the tank of an R33 but i have no idea about stagea fuel tanks.
alternatively the higher output walbro is smaller and easier to fit or perhaps a nismo pump from nengun.
the 044 is a great pump for its flow rates but you shouldn't need it. so i would select any of the above and whichever one is easiest to fit. time = money
https://www.sau.com.au/forums/topic/184060-two-questions/#findComment-3333767
the stagea setup looked identical to r33 to me, so anything that works for them will work. Mine is cable tied in the gtr and it has been fine, including during the big crash at targa. And I've never had trouble starting with the missing check valve.
Re the wiring its actually really easy. Take off the drivers side front wheel and remove the inner guard lining (be really careful with the clips they are pretty old by now. You will see a big opening to the engine bay (comes out near the throttle cable) and there is a big rubber grommet with a loom running through it into the car, it comes out in the cabin above the accelerator
https://www.sau.com.au/forums/topic/184060-two-questions/#findComment-3334083
Thanks for the replies, gents.
I'm getting the 044 at a REALLY good price, so I figured I might as well upgrade now with plenty of room to move in the future should I decide to go over the usual modification path. I'm hoping that the bracket doesn't have to be modified too much, but I'm guessing the 044 is physically larger than the factory pump.
As far as cables for the gauges go, that looks like a nice option, Duncan. I want to avoid drilling holes if I can. Either way, I'm not looking forward to hunting under the dash and carpet for where the hole(s) is going to be.
https://www.sau.com.au/forums/topic/184060-two-questions/#findComment-3334318
don't worry its dead easy to find - once you've seen where it is from the wheel well side it will be easy to find in the interior to - the main engine bay loom goes through there its about 10cm across
https://www.sau.com.au/forums/topic/184060-two-questions/#findComment-3334592
Sweet, this sounds like the go then!
https://www.sau.com.au/forums/topic/184060-two-questions/#findComment-3334840
yes i agree, use hoseclamps instead of zipties if you can, and the 044 or 040 will fit no worries i posted a pic or two in one of the other threads on the subject (i think the thread was about the 040 pump) so search and you will see how well it fits in the cradle. Wiring is simple as said and finding the grommet is simple because the hole is huge and under the foot area on the drivers side closest to the accelerator.
https://www.sau.com.au/forums/topic/184060-two-questions/#findComment-3337034
Dude, I just upgraded my fuel pump, and it's as easy as it sounds. Get a hose clamp (76mm) and you'll be sweet. Just use the bottom part of the fuel pump assembly and it'll work alright. If not, give me a call (0419004274) and I'll give you a hand with anything as I've done the whole thing before.
https://www.sau.com.au/forums/topic/184060-two-questions/#findComment-3337111
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
