R33 Injectors
engo
 Share
ey all, noticed on my r33 gtst which has a 96' engine in it... the injectors are makin this weird tappin noise.. like a really fast ticking and its gettin louder!!.. just wondering if anyone may have or had the same problem or anyone that knows what this could be!!.... cheers guys
Im no mechanic just talking from experience regarding loud tappets..had the issue in my rb30 for a long time...it was a pre-existing problem when I bought that car and was told it had run its oil to low in the past or the oil was too thin.
It is an annoying problem..
Try running some injector cleaner through it, try the eliminating process..
ahhh... cheers fella's... ill chuck in some thicker oil next time for sure!!!...and ill have a go at that cleaner aswell!!... thanx tonnes guys.. as long as its not a real issue i shall sleep betta at night..haha.. thanx again..
befor u do the oil get a really long screwdriver n put driver end on the rocker cover
put your ear on the handle end and listen .
try it on top of each rocker.
do the same on the injectors.
you should be able to tell which it is injectors or some thing in the valvetrain, and go from there
could be nothing but hard to say as only u can hear how loud the tap is .
but some tap from the injectors is normal ,
good luck
good luck
yeah i did that when i first starting hearing the noise... its definately the injectors... bastards!!... cheers for the help!
 Share
    • With my pre/power I use a remote trigger cable(3.5mm jack each end). I turn tv on, it turns both on via ARC. Or, just the pre with the remote or its streaming software, turns on both. Not that difficult at all. Obviously,  you would also want to actually update/upgrade over other factors in your life(bills, family, other hobbies, etc)
    • Yeah, nightfall was very "meh". And I'm crap at pvp, so feels like everyone has cheats(it's just my lack of skill). Final shape has been pretty good. New raid and dungeon are pretty good. If you want to give it a go, probably wait until it's on sale. But, as usual, most of it feels very familiar.
    • This morning was Kingswood's Microscopic Wars. It is the album's 10 year anniversary this year and we went to see them play the whole album as a special show a couple of months back. Was pretty spectacular.
    • Yeah I would like to try and get a ADM car to reduce issues with insurance. I've decided if I end up getting this car I will set it up to be a sleeper build, leave it looking stock/dad spec on the outside I wonder if you can just drop in the 400r/Red/Z ECU or better still use a flashing tool to copy the map off one. Backup the factory map and then flash the 400hp cars onto the 300hp cars ECU?
    • Nah, yeah, nah. Speakers have a nominal impedance of 8 ohm that looks more like 6.4 ohm when measured. The receiver's amplifiers (all channels) are all rated to 6 ohm (I think, it's been a long time since I cared). The real problem is that many modern class D amps have aggressive protection circuitry that cuts off the fun if they think too much current is being drawn. And with my speakers having series crossovers, as opposed to more typical parallel crossovers, and big TL enclosures, they can certainly dip down to lower impedances at some frequencies and that easily triggers the protection. Pioneer receivers are somewhat famous for it, but even Denon, Onkyo, et al, all have many complaints against them across various models. It only does it when listening to music at high levels. You have to be putting your ears at risk to do it. But sometimes I want to do that. If I was serious about using it as a listening room I'd simply upgrade the amp for the front pair to a nice Rotel or something, and just use the receiver for signal handling and processing - although that would be a bit of a pain in the arse too. Have to switch on more shit, pre-amp volume vs main amp volume, etc etc.
