Im sorta pissd off at the moment. Just broke one of my cv shafts for the 3rd time. I did an r200 conversion a while back and have had the worst luck with having, GOOD STRONG, half shafts made up. I never got the original ones with the diff and have had to get them made up every time. Can anyone please point me in the right direction for strength and reliability. I want to make this the last time i do them so i want to do them properly. Im close to just going all out on a 9in conversion. Im only pushing 245rwhp :whistling:
Cheers.
https://www.sau.com.au/forums/topic/184113-drive-shafts-half-shafts-cv-shafts/
As above!! What type of shafts are they being copied from?
I've never broken one, the only person i've ever heard of breaking one was in a dr30 with near on 300rwkw, and he shattered a cv joint due to old age more then anything!!!
If you want a good OE replacement half shaft, get the R31 import half shafts, but you need the stub axle and everything, and they are meant to bolt straight up (both DR30's and import R31's had the long nose R200 LSD)
ill get some pics up and try to explain everything in detail. The first two broke the shaft on the wheel side and this last one has been snapped on the diff side. Very frustrating. But ill get some pics up to help explain the situation a bit better. Cheers guys.
ok, so this is where i am at.
I purchased one of these diffs, just not this exact one. Mine looked like this and came with chopped half shafts.
As you can see they are not complete shafts so i went to a cv guy and he said just give him measurements from diff to stub axle and he will make up shafts to suit. So i did this. First two shafts broke after 5 min.
And now the last set look like this after he chopped my output shafts down and welded on honda cv joints which he said will fix the problem.
Now these have lasted for about 9 months or so, but after a night at calder on friday i managed to break this one too.
This is how i mounted the diff with the nismo housing. I used the original moustache bar and welded on a bar vertically to suit the up and down bolt pattern.
Now im pretty sure that all r200 diff housings are going to have the dimensions.
What do i do now?? I just need proper shafts and im sure i shouldnt have this problem anymore, but sourcing them is not gonna be easy im guessin..
Ah, I see. You are using the longnose R200 with the viscous LSD centre. That would be why you needed to get axles made up. The viscous centre needs that axle with the long output shaft (ie. the one that broke) to work properly. The other one is just a regular old R200 longnose shaft.
Now, if you want "real" halfshafts, I would be speaking to the nice gents at Datsport about them. See if they can get you some, particularly if you want to keep the viscous centre.
If you want to use regular halfshafts (available from a Z31 300ZX at your local wrecker, but getting harder to find), you will need to change the diff centre, either to an open centre, or to a plate LSD item (I went for a KAAZ).
I don't know what/how they made your axles, but that break looks like it is easily replaceable. Did you say it is a Honda item? It is a shame that you didn't get a set of original axles at the beginning. It would have been a straightforward job for a driveshaft shop to have put the viscous output shaft onto the other (say, 300ZX) axle. If I was you (and wanted to keep the viscous), get the driveshaft shop to mate that long output shaft to a 300ZX halfshaft and all will (should?) be sweet. Then use the other 300ZX shaft on the other side too.
My 2.2 cents (GST inc.)
z31 shafts seem to be the way to go. Ill have to try and hunt some down. I dont mind what type of centre i use. I only got this one coz it was the cheapest r200 lsd diff i could find at $290. Everywhere else was asking upwards of $800.
And it would have been ideal that i got the complete shafs, im guessing i would have never had this problem! oh well, nothing is impossible. Thanks for the coin!
how much should i be paying for z31 half shafts and also what is a good CLSD worth?
That's a good question. I bought a pair of half shafts for $80 each ($160 for the pair) from a wrecker in south Sydney about 12 months ago. Sorry, I can't remember the name. I thought that was a rip-off at the time, but paid it anyway.
LSDs are a different kettle of fish. As I said before, I put a KAAZ LSD in mine, which I bought from RMS Motor Parts (site sponsor) for just over $1K about 12 months ago. Basically, any plate LSD that will fit into a short-nose R200 (like the Silvias and R32 onwards use) will fit the long nose R200. What you have to watch out for is the size of the bolts that hold the crownwheel onto the centre. The early long nose R200 had 10mm bolt holes, the late ones had 12mm holes. All short nose R200s have 12mm holes. Therefore, if you have an early long nose R200, you need to sleeve the bolt holes to mount the crownwheel.
I am led to believe that the viscous unit that you have uses the 12mm bolt holes, so changing to a new centre is easier.
Another option that may be worth considering is getting some shafts and flanges from a Silvia / Skyline and adapting them? I don't know how keen you are on getting Frankenstein shafts again...
Im happy to pay up to $100 each MAX but cheaper is always ideal.
Im looking at doing something similar to THIS
From what ive read its the strongest i will ever be able to get the shaft and cv joins without having to use a billet shaft.
So if i can get some z31 turbo shafts im half way there.
I have read somewhere that my crownwheel bolts are 12mm, so thats something positive, and with all r200 housings being pretty much identical that all centres are interchangeable (gotta love the nissans). So im looking at roughly or there abouts $1k for a centre? I hope it outlasts my need for racing!
I have given thought to using silvia or skyline shafts but dont really want to be experimenting again. Im looking to do something that someone has already done sorta thing. If it wasnt my daily driver then i would take more time and look further into it but i need the car back on the road quick smart!!
What centre would i be looking at getting? A 1.0 way 1.5 or 2.0?
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
