50rwkws at 90km/h! LOL, OK then, i take back what i have said earlier as most smaller turbos only seem to make 5-15rwkws more earlier in the rev range....i will take the 50rwkws at 90km/h and happily trade it for a bit of top end. My housemates STI with onkly 200rwkws is so much quicker around town then my car because it so grunty at any rev
a bit late, but here they are:
i'm hoping cam gears will fix the top end and stop it from dropping off so sharply.
  • Replies 132
Posted Images
  • 2 months later...
  • 2 years later...
I have an HKS2530kai on an RB20. 210kw, wanted to run 18psi but it will only spike and peak power is at 16psi. Starts getting fun around 3800rpm but not much before that. Keep in mind my engine is pretty crappy though and timing is very retarded compared to most modified cars as it knocks too easily.
I absolutely love the turbo, any bigger would be way too laggy for street use.
Edited by Kwyjibo
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
    • I managed to get the foam will the original upholstery off in one piece, so will be an easy to re fit thankfully.
