lol its nothing crazy? i just deposited the money on friday and i bank with nab and it would of gone in straight away and im still marked as unpaid :S
im sure its just a mix up or something . ive sent a few pm's about 2 days ago got nothing back... im sure its all fine , but really want to get my status marked as Paid. for that track day.
Thanks Sam :)
Yeah Izzy ive just replied the to your PM, sorry but im a pretty busy person most of the time (eg im at work now but i stopped in a net cafe once i heard about this). Your spot will be ok, i dont know about instant bank transfers cause they usualy dont happen until the next day (as sam said), if you sent it yesterday im sure it will be there monday :)
EDIT: Even better than that, its appeared on todays sheet. Check your status now if you want, im going back to work
Thanks Sam :)
NOOIIICE!! thanks steve. sorry i was just a bit worried my spot would of gone to a paying member. and i just needed to know if i was in 100% cuz im going to the shop to get some tyres now :)
cheers n thanks!
-iz see you there
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
