Hey yall i bought my r32 a little while ago now and am looking to ypgrade the turbo but me being me i have no clue what will fit and what i need so i am hopeing you guys and gals can give me a hand.
Suggestions needed: TURBO, EXHAUST,EBC, COMPUTER, INJECTORS,FUEL PUMP, etc
i have already bought an apexi dyna flow front mount but need help putting it on LOL so useless says i. (hint hint markimark heard you are the man to show me how )
i am looking to get around the 200 - 220 RWKW mark but i dont want to be straining the engine to get the out of it.
Please help me
https://www.sau.com.au/forums/topic/184135-need-advice/
em i was looking at that i while back for mine.
gt 2530 i what i came up with.
i put my front mount in i can help you if yah want.
you need also injectors..
z32 afm
maybe another computer, if you do afm i think....look for a pfc if anyone has one, hard to find for the rb20.
oh and exhaust is the first mod. i have a straight through with cat and rear muff....and 3" dump.
if you dont want a pfc, then the computer is the real debate.
fuel pump...either gtr, or 044 bosche.
a malpassi or any rrfr. (fuel reg) is handy but not needed.
Edited by Oblivion
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3334841
3" exhaust, FMIC, Fuel computer(SAFC, EManage is better) and tune, rb25 turbo, Pod or better panel filter. should be good for about 180rwkw with everything else std. injector on like 90% duty cycle mind you. std fuel pump is good for about that but they are old, and you dont really want it to fail or under fuel, Bosch 044 is good upgrade.
cheap and easy setup with good power and driveable :)
unless you've got a big budget
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3334860
saying that.
you dont even need to do turbo if you dont mind replacing you stock 20 turbo after 40,000 klms if you run like 16-18 psi through it.
but yeah look at your budget, going to turbo set up i said with injectors and what not..
turbo set up prob 1500, then injectors and other on top of that.
but less lag and longer lasting then a stock 25 turbo.
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3334873
yeah i think i like the EMANAGE
i had it in my old project car it it served me well
i have the front mount at home and talking to MARKIMARK about helping me put it on so am already getting things in motion thanks heap guys and gals keep the help coming
AS SOON AS I AM finished making my front and dump pipe my exhaust will be ready wioll have to show you all so you can tell me how i went.
Cheers
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3334876
yeah i wanted to get a TD04 but am leaning towards the 25 turbo less lag.
I also need some advice on where to put my four smoked face gauges i can install them myself but dont know where to put them. i only want to put 2 on the A pillar but i want the pillar mount to look nice and have a good seal.
Edited by 18RZZ
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3334878
z32 afm
EWWW.. im anti fuel regs.. u knw that rohan. the AP engineering PFC is hard to find.. an emanage might be good. dont knw much bout them but knw they r piggy back.
i reckon get a GTR or a nismo sard whatever fuel pump. or i can cut and fit a 040 for ya.. takes 30mins.. flows well :)
Cheers
cheers mate.
start off with the exhaust FMIC and boost. then get ur pump. then work out if u wanna go bigger turbo injectors and afm.. ull then need a ECU. everything after the cooler exhaust and boost up will need a comp really. u can always remap the RB20 ecu. :)
and if u got a bit of cash an apexi series turbo kit would dominate all. one on NS.com
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3334925
i'd be careful about the pillar mount, i have been done before for having them there. but boost i reckon on top of the steering column, and others cut into the dash, or mounted on the side of the clutster.
cheers mate.
lol yeah i know, for us sliders they are pointless, but for fuel economy and rice factor they are good.
i recommend a remapped ecu until you go huge power. i am running one and i dont think 170rwkw is too shabby on a stock rb20. :)
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3334995
sorry i think i might have made a typo or somehthing its
174 RWHP horpower so yeah its slow as LOL
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3335644
nah buddy i was talking about my car. with the chipped ecu etc.
i am running about 220BHP or 170 RWKW...about that.
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3337435
  Bunta said:
thats the hard part
then you have to make it go fast :( though my R32 when it was 205rwkw on the stock RB25 and turbo was pretty fast I suppose
Yeah i would like 300HP, what would be good, or maybe a bit over....but i want it built for response...small full boost by 2,500 or before.
but will see how that idea pans out.
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3337444
well most of you guys saw my car on sunday i think the only thing going for it at the moment was the passenger in the car with me.
so as you all can see i need all the help i can get..
i did however notice that i am the only one without an exhaust system on my car so i think the first thuings i am going to do is the FMIC ( thanks to MARKIMARK performance ) and an exhaust. if the pipe work i make for my exhaust system does not work is there anyhhtaffer i good rane of decent systems (cat or turbo back )
https://www.sau.com.au/forums/topic/184135-need-advice/#findComment-3337446
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
