Car:
1992 R32 GTSt M-spec
Stock dark blue – rare colour that only 5% of R32’s came out in
Imported in 1998 with normal compliance (this is NOT a car imported under the 15yo rule)
Engine/Transmission:
Rb20det with 150,000 genuine kms,
4sp Automatic with MV automatics stage 2 shift kit and 2800rpm high-stall torque converter. This retains the converter lockup. Large front-mounted transmission cooler. (if you don’t know what this all means, just ask me – the transmission mods make the car very nice to drive and the car chirps the 9” rear tyres between gear changes in the dry!)
Engine mods:
Rb25 series 2 turbo (nylon compressor wheel, ceramic exhaust wheel),
FMIC,
tomei poncams 256deg,
HKS cam gears
3” stainless split front/dump pipe, 3” stainless cat, 3” cat-back with stainless cannon muffler
Splitfire coilpacks
Walbro in-tank fuel pump (supplies more than enough fuel flow for the car)
Tuning:
Full live ECU tune of the stock ECU through Nissan edit at Mercury Motorsport using Dr Drift’s software – made 155rwkw with 12:1 AFRs with a conservative tune to maintain reliability
98-octane BP ultimate or shell v-power the only fuels used EVER.
The cam gears, turbo selection, and tuning have been designed to bring boost on as early as possible. This makes the car very nice to drive on the street with a LOT of midrange torque.
Body:
GTR front bumper with N1 air vents (stock polyurethane plastic, NOT fibreglass!), M-spec sideskirts and rear pods. M-spec rear spoiler. Clear front + side indicators
Volk F-zero challenge rims with 90% tread Nankang NS-II tyres. 18*8 at front and 18*9 at rear. Wheels have been polished professionally and look amazing. These wheels + tyres on their own are worth over $2500 and suit the car 100% perfectly
The guards have been rolled at the rear to accommodate the 9” wide rims and 255 tyres
35% tinting sides/rear with lifetime guarantee from tint-a-car
Brakes and Suspension:
Bilstein setup form the SkydeyKid group buy, lowered 25mm to a legal ride height (this suspension alone is worth $1500 and is very high-quality)
Whiteline caster kit
Super-pro polyurethane bushings
Front and rear strut braces
Bendix ultimate pads on stock M-spec brakes (4-piston front, 2-piston rear)
Brake master cylinder brace
Brake fluid changed in January 2007 using motul fluid
Interior:
Leatherette seats, in ivory/cream (rare!) with matching handbrake boot
Black car mats with Nissan logo’s
Aftermarket steering wheel (Nissan) and aftermarket automatic gear knob
Oil pressure and boost gauges
Pioneer head unit with inbuilt CD player/radio and additional 6-stacker in the boot. Comes with remote control.
Climate controlled air conditioning converted to new aircon gas. Re-gassed in January 2007.
Alarm:
4-point immobiliser with alarm and back-up siren. Also remote central locking that works with the alarm in one press of a button. Intergrated digital turbo timer that works in sync with the alarm
Maintenance:
Motul turbolight oil + filter changed every 5000kms
Automatic transmission fluid changed every 20,000kms
Spark plugs and fuel filter regularly monitored
Timing belt changed at 140,000kms when cams installed (gates racing timing belt)
All major servicing up to date including full 100,000km service done at correct time.
SOLD ! !
The parts used are of high quality (not cheap crap) and this is the most amazing R32 to look at and to drive. The car has been setup to have lots of midrange and the turbo comes on very early. The car also looks amazing and is very comfortable. Plus, it has that great rb20 sound, enhanced at idle with the cams making it sound like a bulldog rather than a pussycat!
Selling due to the fact that I have just bought a 2003 V35 350GT!
This car made me very happy for 4 years and I hope that it can continue to make someone happy for a long time to come.
Cheers,
Warren
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/184136-1992-r32gtst-dark-blue/
why the 89 dash?
do you mean the blue gauges?
blue gauges wasn't only series 1, as i understand it was dependent on the car colour also
...but let's keep it on the topic of people buying my car!
any other stuff feel free to PM me
carsales
got a few tyre kickers in the end that had NO idea but the guy that bought it realyl appreciates the volks/bilstein etc that it has and actually knows that its worth significantly more than just a normal auto skyline (which can be had for 8g or less)
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
