Yes that helps, thank you. Is the E-Manage fine? I dont know the price for the SAFC but the E-Manage is pretty cheap. Where would I get Auto Shift kits from as well as a high stall converter? Which brand of boost controller would you recommend?
Thanks
Help
A TURBOTECH bleed valve is fine, costs you about $30 or so. Proven to work very well.
http://www.skylinesaustralia.com/forums/in...amp;hl=$22
SAFC II is made by APEXi and is a fuel only computer, roughly about $250 - $300. This is fuel only and doesn't support after market injectors so dont think it will be ideal for you.
E-MANAGE is a good little unit, again dont know much about it or the price, but do a search and you will find heaps of stuff about it.
REMAP will probably be cheaper, so if you get everything done at once, then just take it in for a tune and leave it.
See how you go though.
Edited by abu
Ok Thank you, will start buying parts now. I checked on Just Jap and they have a 570cfm hi flow cat for only 200 dollars. I am going to get that and the front pipe and will do the first mods.
I will let everyone know how it comes out.
Thank you everyone
As a rb20 owner myself, and having worked my way through my fair share of mods i have found that sometimes the simplest things make more improvment than you would think.
From stock I added:
Cheap chinese t04e
highmount manifold
12psi
Cheap FMIC
about $1100 all up
Made 170kw or just under 230hp
From there i added:
BOSCH 040 fuel pump
GTR injectors
Apexi AVCR 14.7psi (1 bar)
Full turbo back exhaust custom front pipe and dump pipe and trust stainless exhaust
Highflow cat
Garrett GT2876R
Low mount manifold
Microtech LT12S
About $5500 all up
I then dynod it at 228kw or 306hp
But now i have taken sort of a weird step some might say and buying a rb24 comprised of a rb20, using rb26 crank and rods
Some of its goodies are:
Garrett GT3076R
Stainless highmount manifold
Custom Dump pipe
Adaptronic ECU
SARD 650cc injectors
JUN 272 cams
HKS cam gears
Forged Eagle H-Beam rods
Custom ROSS pistons
TRUST 1.5mm headgasket
Ported and polished head
Custom made and designed intake plenum
HKS oilcooler
HKS tripple plate clutch
ACL race series bearings
Around the $10,000 mark so far
Looking for 500hp plus on 25psi
So its all about what your goal is and how much money you want to spend. Its best to start with the small things and you will picup and learn what aspects make more difference thanothers and sometimes the really expensive items make less of a difference than the cheaper ones.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
