Hi Guys,
Bit of a book here, but I hope it all helps.
In March our CD player in our car started playing up, it would click for about 30 seconds whenever you started the car, sounded like a grinding of the trays on the 6 stacker. Anyway after months of looking for the solution to this problem I finally went about getting stuck into the unit to find the problem and to try and fix it.
Now there is a lot of information in www.g35driver.com
in regards to this problem, it seems to happen a fair amount and usually the best way to fix it is to take it to the dealer for a replacement under warranty. However seeing as most of our cars do not come with a Nissan Warranty we are stuck between a rock and a hard place.
I followed the instructiions provided on the g35Ipod install DIY as well as the many DIY on the g35driver site.
All the information is fantastic.
Now I finally got the unit out and had a proper look around, it appears that there is a problem with the actual CD player and not the trays themselves.... I am ok with that, as I finally have all the CD's out so there is no Clicking noise any more... However and I must stress this... There is a white connector that goes between the Radio Controls Circut Board and the Radio Unit itself... The little metal filiments are very fragile and are prone to flaking whilst you work on the unit. Once I completed the work on the unit, I started to reassemble everything... But the filiment had broken off slightly on the one end... poooof!!!! Fried the LCD / LED Radio Display ....
So now we are on the hunt for a new unit. I will go through Nissan Aust to see what prices we are looking at for a whole unit and also for the Display Unit....
Start Counting the Dollars Gentleman.
Edited by MIKE_R32_GTR
https://www.sau.com.au/forums/topic/184189-bose-head-unit/
Hi Guys,
ouchies that will cost you mate.be thinking in the hundreds of $ possibly 1k or more.
i f i was in your situation i would consider replacing the unit with an aftermarket double din cd/md player.Hopefully the bose /clarion unit is not necessary for the cars normal functioning like the dvd rom unit is....chris will know
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3335378
For the Circuit Board we are looking at around $250
For the whole unit +/- $700 if that is the case... Pioneer DVD / Touch Screen Install...
Will keep you all posted
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3335535
there are aftermarket leads available to make the bose amp work with other units. just a thought:)
thats the best option.
can they be ordered thru FAST or from a japparts importer?
hopefully the lead isnt too expensive.
so is the lead universal,or would you need one for sony,one for pioneer etc?
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3336045
jap parts will do the facia bits. the leads come from elsewhere.
I'll have to check if the local supplier i deal with has them.
waz,
yep same guy. I'll probably make these since the last one was 180deg out!
the DVD one will depend on demand. I'm not going to fork out $500 for 1000 plugs (persay) and not get a return on it. your lead will determine if he can get the plugs. again I'll probably make this one too.
its all packed up ready to ship out in the morn.
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3336443
waz,
count me in for the dvd lead chris.
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3336935
leads are universal (for nissan bose ) . there is not a plug and play solution for these cars.
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3338919
only thing it will affect is the external audio. IE nav and TV. that can be fixed if you use the correct radio :) (IE blaupunkt.)
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3338925
btw leads are available here :) I checked today. think twice if you are going to swap this thing out as it will not be a cheap exercise.
I had a call today about this from a fellow with a 250GT asking a similar question so I thought I would clear this up.
to do it properly with a screen - no real change from $2k.
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3342295
Chris,
Already looked at that. not sre it the unit is the same, but the controls and facia circuit board are completely different,
Was thinking of getting the parts in Dubai at an Infinty Dealer as they are cheaper than here.
Got the costs from Nissan I was way off.
Facia $1160
6 Stack CD Player / Radio $ 2400
Any Ideas?
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3347957
I was looking at another question actually. seems the cd mech in these things dies so IF a 350Z was teh same it would be a direct swap. I do know that the 04 pathfinder unit runs the same board (sans front panel in your case.) and same controls internally. been down that route looking at another question.
so what EXACTLY is wrong with yours??
have you given autotainment a ring yet (since you are in perth.) ?? was talking to him about a few other things and your topic pooped up. give him a bell - may be able to help.
https://www.sau.com.au/forums/topic/184189-bose-head-unit/#findComment-3348672
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
