http://youtube.com/watch?v=R_oPRiMRs68
hi all, i just recently noticed my tacho doing crazy things, it either does as in the video, or hesitates for a moment
then keeps going, also the rpm displayed is slightly off as well, it does it when driving or when reving at stand still, all the
other gauges read correctly. do you think the dash cluster is on its way out or could it be another problem?
any suggestions would be awesome guys :) thanks
https://www.sau.com.au/forums/topic/184196-tachometer-dying/
Where would he get a speedo cable from? You guessing or has someone actually had this problem?
I'm just assuming that the speedo cable is the problem. You can get speedo cables from wreckers, but they could be stuffed aswell. Best to get one new from Nissan. I think it was about $100.
R33 doesnt have speedo cable its electronic!!!!!!
Not to mntion his problem was with the tacho not speedo lol...
Pretty sure its a cold solder joint or similar that causes it on the back of the dash cluster, just buy a new cluster off ebay or wrecked r33, alternatively, it gives you a good excuse to upgrade to a nismo 320km/h dash cluster ;)
Edited by MintR33
Pretty sure its a cold solder joint or similar that causes it on the back of the dash cluster, just buy a new cluster off ebay or wrecked r33, alternatively, it gives you a good excuse to upgrade to a nismo 320km/h dash cluster :wacko:
:rofl: I didn't realise 33's didn't have these speedo cables. I just assumed that the tacho problem was related to the speedo cable. :(
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
