I've been reading as much as i can so far on this problem that happens in most r33's and to no avail i still have a problem with mine.
it seems that my switch has slumped down and it keeps the relay clicking when the car is running and is starting to burn out the motor, my window goes up and down but only when i hit the motor and it seems to work, other times it just refuses to move at all, just the relay keeps clicking, any advice on how to go about this..
i really can't afford to take it to an auto lecky, i'd rather do the work myself but my question is do i need a new motor? im going to try chase down a 2nd hand switch, ive tried friends switches and still does the same thing, leaning more towards it being the motor. but if i keep the switch and buy a new motor and it fixes the problem most likely its just going to burn out the new motor i put in the car.
any advice on what i should look for, i hit the motor and it works.. then randomly stops working is just stupid, ive checked all the wires cleaned them everything i could think of kind of stuck at this point.
- kent.
https://www.sau.com.au/forums/topic/184205-drivers-side-window-motor-button/
- kent.
shit i pressed the add reply button b4 i wrote n e thin!!... ummm i yeah its a bastard of a thing!!!!.... i just spent last night and this morning on it... the black box next to the handle when u take the panel off is the teller if its the switch or sumthing else... the circiut board inside allows u to control the window... and it probably will work fine from there... so try takin out the switch all the way down to the electrics and u will find the 2 lil switches there... and if its like mine ull just need to replace the lil white switch thingy on it.... im still not sure where to get mine though... but yeah.. hope this helps..
ive pluged another switch in doesnt fix it, tried another box aswell didnt do anything, also have just taken out the electric board still looks alright both white things for the up and down move in the box, going to re-solder it tomorrow, so after that im stunned, and thinkin just going to buy a wreckers door and replace the whole lot...
bloody electronics!!... bastards of things... ummm... seeming u tried all that.. maybe it could be the motor for the window... however its 99% that its the electrics.. ummm... maybe try goin to a auto lecky and gettin a quote b4 replacing the whole door... ahh well... soz i couldnt be of much help
ive re-soldered the whole lot to the switch and the relay box, didnt help so need to chase up another motor now, getting tired of shit breaking, auto lecky meh i'd rather do it myself than pay someone my wage to do it for me :)
I had the same problem, you just need a new switch.. Just purchase from the wrecker..
I had this same clicking sound and it did burn out the motor but I got zoom imports to fix the motor for me.. Make sure you get the switch fixed before you fix the motor because it will break again easily.. I think Zoom charge about $160 for this.
You're in brisbane right?
mine sticks and clicks as well quite annoying isnt it. my switch gets stuck down if i pull it back up a tiny bit after winding the window down its ok. But yeah I will replace mine soon too
i got a window motor from alljaps vaginia for 125clams, and a switch from the for sale section. takes about half and hour to change the motor over then change the switch when u put the door skin back together again.
if u want more infor on how to get the motor out then send me a PM and ill try to explain it (its pritty easy).
AiF
  • 11 months later...
Resurrecting this to add my experience with this problem.
I had the same problem with the clicking inside the relay box and no up or down with the window.
I opened the relay box from the connector end and checked the soldering to find one of the pins had cracked solder on the underside of the pcb board. Added more solder to this pin using a soldering iron and voila, window winds up and down.
If you're gonna replace the relay box, give this a go first.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
