Guest Tempest
Now there is something i am somewhat unclear of...
I have asked twice already if you import a car from japan do all mods have to be removed and destroyed... Both times i have got the answer "correct"
Now.. could someone explain why it is that anyone would purchase a car "highly modified" if all the mods are to be taken off before they actually get it?
This may seem very noob of me but i intend to import soonish.. and i am getting some idea's of how it all works.
I downloaded the FAQ's from www.prestigemotorsport.com but it didn't answer the question fully...
https://www.sau.com.au/forums/topic/18421-car-details-before-purchase/
  • Replies 43
It is dependant on how the car enters the country, so there should be nothing to stop you taking off the parts overseas and shipping them with the car .. as long as the car itself is 100% stock and any aftermarket parts are not fitted prior to registration.
it all seems to simple to remove the mods and get them shipped over seperately ... its going to cost $'s to:
a) remove the mods
B) source stock bits
c) install stock bits
d) send over original mods seperately
e) re-install mods when landed
i wonder by the end of it how much you've really saved...?
  • 2 months later...
Question:
When is a RAW NOT a RAW?
Answer:
When they leave on or re-fit after market(non-conforming parts) with-out evidence!!!
This is going to be a huge problem for "some" of the RAW workshops here in Aust particularly the ones importing Skylines,as to import and sell a stock33 will be about as saleable as a" pair of trousers filles with African killer bees" . and some Raws have allready gone out and publically said"If they think I am going to remove a S/Steel Trust exhaust of a vehicle and destroy it ,they must think I am a F%CK$# Idiot" un-quote!!!!
I wonder how long someone will be a RAW for with that kind of attitude?
What would happen to somebody who has paid a deposit to a RAW to import a modified Skyline, and the vehicle gets inspected and the RAW gets an audit and nailed? where would that leave the client and his vehicle???
  Quote
Can someone PLz answer this question
A raw without a licence... workshop... and probably in Jail.... or fined heavily.
The customer..... without a car... and probably out of pocket a lot due to the car (probably) being destroyed or re exported.....
(Just guessing here)......
hehe..
anyway, i wouldn't be trying to get an importer to push the rules as they'll be regular inspections. The only people that are going to suffer from this are those trying to do the dodgy, or you when you're car gets taken back or destroyed. That is one of the whole reasons the new scheme was brought in the first place, to stop some of that from happening.
  Quote
Originally posted by P1E
I am currently importing a vehicle through Geoff and he has assured me that this is untrue. :confused:
Yes, that is true - ALL aftermarket parts will have to be destroyed or re-exported with evidence provided to keep the RAWS out of hot water when they get checked out by the DOTARS.
At this stage it appears that this may even include stupid things like gear shift knobs and additional gauges .. nobody really knows how strict they will be with enforcing these laws so it will be a case of "better safe than sorry"
I would not personally suggest importing any car with modified parts unless you are prepared to lose them and wear the cost of buying stock parts to replace them .. trying to "sneak" anything through at this stage would be just plain stupid for you and beyond belief for the RAWS workshop.
Hi Pie,
If you are talking about a 15Y/O vehicle, a/m gear can be left installed as the only dramas you may encounter will be the local Licencing authorities. and it may just be a case of removing some of the parts to licence the vehicle.
Although if you have been "promised" a vehicle imported by a RAW(SEVS) vehicle with the non-conforming parts retained or re-fitted then be very very carefull. In fact if anybody from"DOTARS"is monitoring this thread then I would say you are allready shot! and possibly the company you have mentioned!!!!!
I would guess that if a RAW was caught out with your vehicle in his premisis that was signed -off and found NOT to be conforming to his evidence ie:17" Rims fitted or S/steel exhaust ect then you would be without your vehicle, and DOTARS would not care who owns it ,as it would come down to a legal claim between you and the RAW, not DOTARS.....
I'm looking to import a relatively stock Series II R33, although a couple I have looked at have had a few small extras (GT-R seats, rims, gauges, etc.).
I was originally under the impression that all aftermarket parts had to be destroyed, but Geoff explained that such rumours are completely unfounded.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
