  • Replies 43
ive got a question, what is the point of this stupid rule anyway, as that other guy said, if the vehicle could be roadworthy with the mods on it, why won't the government alow it?
Its seems that at every possible step of the way, the government likes to make it difficult to own an imported car...
sumfatchin, the government wants to stop imports or make it hard for people to import cars. that is the reason for the new rules.
Basicly imports take away from Australia Shop (car-yards) making profit, and also bring the value down on cars that some caryards sell
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
