I would go to one of the truck places and buy a four inch RUBBER elbow. These are used in big rig truck air induction systems. Truck snorkel intake diameters go from three inch to ten inches or more in diameter, and you can get hoses and bends fairly readily for all the sizes.
as above guys, do you guys have anywhere in oz where i can buy a bend. its for my air filter to turbo.. cheers bernie uk needsa to be 4" diameter and have about 6" legs.
If by 'alloy' you mean non-steel, read no further as this post won't help you :D
You probably want something like this:
http://www.mandrelbendingsolutions.com/servlet/Detail?no=436
Any exhaust shop should be able to get you one easily in mild or stainless steel
in a reasonable variety of wall thicknesses. You probably don't want it as thick as
the one above given that it's for the inlet side...
Just ask for a 4" right-angle mandrel bend in the wall thickness of your choice
Regards,
Saliya
cheers saliya.. will think on that.
warpspeed, its from the air filter to the turbo, when running high boost and long silicone legs on the bend i have seen then collapse under suction. i suppose the turbo is trying to pull so much air through the filter the hose just gives in?.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
