yep thats me ;) what a spew no body got it on vid i would have liked to have seen it from the rear , its not fair i never get to see my car from the outside when its moving :)
You sound like the kinda dickhead that gives enthusiasts a bad name.
Wish there was footage, i'd send it to the Police.
Word of warning. Talk about idiotic behaviour around here, and you wont be around long.
SAU has no time for muppets.
  • Replies 256
Posted Images
Not sure its worth the trouble to mask the plates in the still shots
as most of them are in the videos where its near impossible.
If the person doing the DVD video wants my DV file in high res tell me how to get it to you.
Even if its better to give you the tape let me know. Unfortunately my camera was not set right
until the Angelsea Departure, then I had to head back to Melb. ;)
Aww crap...
I was enjoying working on the vids so much I forgot to tape Californiacation for the misses...
Anyone tape it???...
lol i have it will give it to ya when i meet up with ya
does anyone know a good program i can use to downsize my vids??? wanna post up samples on youtube coz this DVD thing might take a tad longer but vids are to big.
3rd vid is being uploaded to YouTube now...
I picked the music for cheese factor... ...and because it was the same length of time as the clip... ...Kinda how I picked the music for the Pier Walk vid... ...All the other tracks around the same time were too (V)etal or too far out there...
Plus... ...I got to do the spandex dance while it was encoding... :PBJ: ...it kinda looked like that...
what format are the vids in? if there .avi / .wmv etc you can just use windows movie maker and down size em with that.
dvd format stuff i dont know too much about.
all good.
figured out how to use cyberlink powerdirector lol
im uploading a small preview of my vids. once i have vids from other members i will let you guys know about the DVD
is there a limit of pics i can post i took about 267, and cut it down to 100 and something lol
i wont post them all but i got some good pics of other peoples cars i'd like to post, i'm just editing out the number plates now!
do you have photobucket??
if you do then just upload all you pics on to that and post the link of you album here so ppl can just go through them.
if you dont try compressing all the pics into a zip file and email it to me and ill host em up on my photobucket for others to see ;)
Oh cool, i'll post up some of the good ones, and i'll put togther the Photobucket Folder!
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
    • I promise there will be no chance of replacing the rad support....  It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
