Yeah like mentioned closed where hole in the road is... i used this arvo to get home from erina and i get on f3 at gosford and get off at the first exit can't remember what its called but its the one straight after you up the huge hill lol.
But lots of pol pol patrolling it now, even during the week i've seen a few... today was nuts sore like 3 cop motorcycles and 2 hwy patrol - spose with the f3 being a stand still they had nothing better to do.
https://www.sau.com.au/forums/topic/184274-oldpac/#findComment-3337050
  Primordial said:
I still think they should turn it into a one way touge course and charge a fee per run. I'd pay $10 a run to belt up the Old Pac at full steam! :)
I'd be a pretty poor guy by the end of the week.
https://www.sau.com.au/forums/topic/184274-oldpac/#findComment-3338809
  Primordial said:
I still think they should turn it into a one way touge course and charge a fee per run. I'd pay $10 a run to belt up the Old Pac at full steam! ;)
If only......
The locals would bitch and moan if you did that, even if you cut them in on the fee. They were probably the biggest force behind getting Race to the Pie cancelled, even though there's no houses on that hillclimb between Mooney and Pie in the Sky.
https://www.sau.com.au/forums/topic/184274-oldpac/#findComment-3339719
  scathing said:
If only......
Yep they like to bitch, my dad rides the ol pac on his bike all the time and last school hols (hes a TAFE teacher) he got pulled over 5 times in 3 days for random "rbts" - the locals apparantly don't like the noise of bikes too early in the morning ;) .... although late Monday & Tuesday nights is good for a clear run.... not speeding of course :)
Seems much easier these days to do Spencer and wisemans rd :D
https://www.sau.com.au/forums/topic/184274-oldpac/#findComment-3339886
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
