Hey all
I have a Link Plus ECU and harness to suit 32/33 GTR Skyline for sale. Being a Plus it has quite a few features which include Anti Lag, Launch Control, Flat Shift, boost control etc The harness that has been made enables you to simply plug this ECU in to your standard GTR plug and start tuning, no need to cut up your standard wiring harness. The map sensor is also a direct plug in to your AFM plug meaning all the messy wiring has been done for you. Included with this ECU is a 3 bar map sensor and manual. Currently it has a tune for a T78 with 1000cc injectors. Asking $800ono
Also for sale is a set of 6 standard GTR coil packs. These are in perfect working order. Offers....
Location is Sydney and we are willing to ship at buyers expense.
We also are in the market for an RB25 5 speed gearbox so if anyone has one for sale could they please PM me a price, condition and location
Brad
https://www.sau.com.au/forums/topic/184298-fs-link-plus-ecu-rb26-coil-packs/
pictures of ecu setup?
which link plus version is it?
is it the link harness, or a home made harness?
Edited by -==L=a=N=c=E==-
sorry about the quality of the pic, it was taken with my camera phone
Its a link plus version 14
it is a harness that was made by myself. I work for Advan Performance so its not a job that has been done by somebody with no idea. It utilises the Link plug obviously and that has been spliced into half a GReddy E-Manage harness. The car has been running like this for about 3 years
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
