hello all, ive lurked here before, using the search buton alot to gather info. Since skylines are rarer than smart presidents here, I can only pretend by owning a s13 coupe with rb20/5 speed setup. Just thought I would say hello after I've Lurked for so long.
https://www.sau.com.au/forums/topic/184349-newbie-from-the-us/
lol welcome... don't sell yourself short there... JFK was a smart president, dunno bout the mob that came after him though ;)
I've followed some of the buildups you guys do over there (mostly on ziptied), and I must say the quality of work and the attention to detail in some of the builds is really good over there. Did you do a face swap on your 240sx? how's support for the RB's over there?
yes did the face swap, as I dont care for look of the us. spec 240sx. as for support, depends on the Rb motor. rb20det=parts harder to come buy, engines themselves arent horribly expensive compared to sr20dets, etc. rb25det=more aftermarket support, more expensive engines and of course the rb26dett over here brings in a good amount of money and good amount of aftermarket support.
here are some pics, yeah I need paint, lol
Edited by 200sxRb20
nice sil, very close to a typical aussie street silvia. whats the paperwork like in regards to importing and installing a foreign engine?
is the 30y/o rule true? ive seen pics of all the old C10s and the like, how common are they over there?
i'm pretty sure that the silvia and sil80 were factory imports in america (hence the steering wheel being on the wrong side, LOL).
hey dude, welcome to the forums. don't take anything ctjet or myself say too seriously. we are the resident bully's of wasteland.
they are also lovers...
you're half right.... the 180 (240sx) and the onevia are factory imports into america
as apparently the silvia headlights were too low or something so they didn't meet the US road regulations
lol, the ninjas are my secuirty system. as for the silvia imports, we got whats called the 240sx coupe and hatchback, Ie the silvia and 180sx respectivley. the front end was swapped because of the headlights, and instead of the sr20det, we got what we refer to as a truck motor(same motor that was placed in the nissan trucks here in the us) the Ka24e and later on the ka24de(hense the 240 name). its kinda crappy, so most people do the conventional sr20, rbxxdet/t, or ca18det(as well as more uncommon v8 from various makes) swap.
as for the rules on swapping the engine, depends on the state/city you live in. if the area you live in does emissions testing it can be an issue, but depends on the test they do. if the car is a certain age, they only do the "sniffer" check, so you can get away with it with a cat. converter, etc. now if they do a visual inspection, well, they are obviously going to know, and you will not be able to get it registered to drive. Luckly I live in an area that doesnt do emissions area so I dont have to worry about it.
and the squishy pipe, nah its not the actual pipe, and now that I think about it, I cant remember why exactly I had that shield on there. I know it had a purpose at one point or another. but thanks for the welcomes, look forward to learning from you guys(and gals?)
and here are my mods just for reference.
RB20DET(from A31 Cerfio if i remember correctly)
ARP Head Studs,
GReddy 1.2mm Head Gasket,
GReddy Timing belt,
Fidanza adjustable cam gears,
Hybrid FMIC and piping,
Turbo XS BOV,
HKS pod filter,
3" exhaust with Fujitsubo NGK axle back,
GTR fuel pump,
Koyo radiator w/ dual 12" fans,
GReddy EManage,
GReddy Profec E-01,
GReddy Auto Timer,
HKS Hypermax D coilovers,
front camber plates,
Cusco front strut bar,
Cusco front tension rods,
Zenki Silvia front end conversion,
Silvia Dual Projector lights,
16x7/16x8 SSR Integral A2 wheels,
225/40-16 Toyo Proxes T1-S,
R32 GTS seats,
Sparco wheel,
R32 tach in S13 cluster
silvia headlights aren't DOT approved, 180sx pop ups on the other hand are easy to change to DOT approved ones. Rather than redesign the silvia headlight (so that it dosen't glare into oncoming traffic etc) they just replaced the front end with the 180sx front.
Guys in japan saw this and started copying the americans... and the onevia was born.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
