OMG THE STEERING WHEEL IS ON THE WRONG SIDE!!!
Yep, it still messes with my head seeing s13 interiors the other way around! :)
You'll find a lot of people who are fans of the RB20 here, I'm not one of them, (nicely sorted out engine build by the way) but they're here anyway if you need help. While you might consider it unfair not being able to easily get SR20 bits, I also think it's grossly unfair how easy it is for you guys to get guns and how damn hard and expensive it is to get them here! :D
Edited by MK2
You'll find a lot of people who are fans of the RB20 here, I'm not one of them, (nicely sorted out engine build by the way) but they're here anyway if you need help. While you might consider it unfair not being able to easily get SR20 bits, I also think it's grossly unfair how easy it is for you guys to get guns and how damn hard and expensive it is to get them here! >_<
nah the sr20 parts are very easy to find, the engines are everywhere now. its abit harder to find a stock, non-swapped 240sx" than a 240sx with an sr. its the rb20(specifically) thats hard to find parts for. but I got what your saying, lol.
Being in the army, weapons have lost abit of their "luster"
and what is it with you guys over there driving on the right hand side of the road? is america just like a big kid? they thought "england drives on the left, and even though we are a colony of england i don't listen to anyone so i am going to drive on the right!"
actually 2 thirds of the world drive on the right... we're the minority. Also mass motor transport came about in 1900's, many years after they gained independence in the 1770's. And the first dude to make a car was european (french or german... can't remember), so they'd have driven on the right anyways >_<
don't give me answers on topic!
but if you go back to the origins of it it goes back to roman times when they drove their charriots on the left so the the wip wasn't on the street side (since most people were right handed and carried their wip in their right hand). then when napolean came along he just made it however he wanted but he never got as far as england so they stayed the way they were.
  • 3 months later...
actually 2 thirds of the world drive on the right... we're the minority. Also mass motor transport came about in 1900's, many years after they gained independence in the 1770's. And the first dude to make a car was european (french or german... can't remember), so they'd have driven on the right anyways ;)
i'd like to subscribe to your newsletter :banana:
could you please tell me the meaning of rhetorical?
thanx.
BTW Welcome to the madhouse Matt
    • The boot notch on the GK Tech rods is different to OEM yes. You'll find a solution. They are a good rod, I have used many of them for various setups, and no they are not ' just for drift cars', they are fine as an OEM replacement. Same goes for the tie rod ends although I found they transmitted a huge amount of NVH a normal balljoint masks, making it feel like there was something loose or knocking, even though there wasn't. If you used the same pieces on each side, no reason one angle should be different to the other side. Have you checked ride heights/measured the angles? Or just visual? Your alignment will be massively out of whack yes. Up to you; it is worth taking the time to learn wheel alignments and do it yourself. I have never had better wheel alignments and I haven't taken my car to a shop for, dunno...many many years. Spend a few hundred on equipment, do alot of research via online articles, youtube vids, and "trial and error" on setups. Eg, set it with too much toe-out, toe-in, too much or little caster, drive the same stretch of awesome twisty mountain road each time, learn how they feel and how the car's handling has reacted to your changes.
    • Won鈥檛 be hard to beat them. 馃ぃ Farken sponge cakes!
    • Nah I did not will have to another time. I only installed a blitz return flow FMIC probably 1000kms ago. When I took the old piping off there was basically no oil in piping. At this stage it has to be valve stem seals. When I roll down a big hill in gear and then throttle down the bottom, I get the same puff of smoke.
    • I believe when they added coolant to cool the turbo it negated the need for turbo timers as water continues to flow even when the engine is shut off I forget the actual terminology, I'll just say the coolant "percolates" through the turbo which stops the oil cooking itself to death  Well....that's how I see it, as all the plant at work that has coolant lines to the turbo can be shut down straight away, whereas the older plant with only oil feed to the turbo you need to idle it for a few minutes
