Hey Chris,
Here is the picture you asked me for: post-52623-1214314612_thumb.jpg
You can see that there's nothing on top of the Bose amp.
I've also included a photo of the front panel
you can see that there is no tv button but an A/V one.
I think that an optional Xanavi navigation system has been retrofitted to the car. The third image is a remote control, see this link for more info. http://www.nissan.co.jp/EN/navi.html
The language is all Japanese.
What do you get if you disconnect your tv tuner ? I might have one hidden somewhere because of the snowy screen displayed when TV mode is selected.
Thanks again for your help.
Gerald
Hi Mate:
Your GPS in a non-standard GPS, so as the TV----------I Guess.
But as long you have snow on your screen, there should be a TV turner somewhere, have you try the driver side or some where inside the golve box.
It should be somewhere.
I will double check tonight, but the only antennas i see are located into the windshield, passenger side.
Do you know where I can find directions on disassembling the glove box ? i want to check behind that.
Thanks guys for your support :thumbsup:
Gerald
glovebox is easy. drop ALL the visible screws and the two on the lower corners. it will then pop out. there is a light and the airbag harness attached to that - drop those off.
do you have the nav unit in the OE spot. if so can you take a pic of it also do the same with teh antenna setup.
common place for the nav units to go is under a seat. look there. out of curiosity where are you?
Hello,
I tried to remove the glovebox, i only see 1 screw on the right lower corner, nothing on left, will try again soon.
I removed the carpet on the passenger side, found a Hitachi box, but I think it's not what i'm looking for ... and a HKS speed limit remover :)
Apart from that, i have the same nav unit, same location as yours.
I took a pic of what i believe is the antenna. Am I right ?
Can you tell me how the TV antenna harness looks like on your car ? I want to find and follow this up to the tv tuner.
BTW, I'm live in Mauritius :)
Bye
Gerald
Hello,
I removed the carpet on the passenger side, found a Hitachi box, but I think it's not what i'm looking for ... and a HKS speed limit remover :P
BTW, I'm live in Mauritius :O
Bye
Gerald
I think the factory antenna is within the rear glass, so it is invisable does no like yours.
That means your TV unit is something different maybe the Hitachi box????
Edited by Frank350GT
show me the hitachi box. if it is tucked under the carpet then there is a good chance it is the TV tuner. I'll know when I see it. show me the inside of the car particaluarly the nav unit and screen (in operation.)
yes guys I'm up to something :/
Hi guys,
Chris, here are the pictures you asked me for:
One question: I can select the tv mode using the AV button. I don't get any sound. On your pictures, i see that an AUX input is selected. I don't have any aux button. How do you select this input ?
Thanks
Gerald
ok commnets in order of images:
different nav unit. the ones in the cars I see is black and has a single open CD slot.
same disc as the OE unit.
your car is an auto. that is the controller for the gearbox. also noted the speed cut disable box. chase the cables to the left of that image. that will find the TV box. need a shot of that.
same screen. would love to see the rear (wiring side) of it. would almost bet its entirely different to the OE one.
TV setup - quite different. never seen that.
need to see the TV box. if its there (aux) then I'd say it would be a function of the buttons. on the OE one its a function of the TV and TV menus.
  • 1 month later...
Hi guys, I m on the market for a 2001-2002 V35 sedan.
After driving around my friend's 2004 sedan (with reverse camera), I m sure I need a camera too.
However, most of the cars don't have a reverse camera (well, actually I haven't seen one with them yet), so I will have to install on myself.
After reading this thread, it seems possible to add AV to the stock LCD.
Can someone confirm these (sorry it's a bit confusing with some of the photos missing)
- is the 6-pin white plug at the back of the TV unit for a camera or for a AUX in?
- is this entire mod just the 6-pin white plug? anything else involved? (Sorry, everything I see seems to only involve the TV unit/white plug?)
- there are comments about the video blacking out when car is moving, how will this affect a reverse camera setup?
- when looking at cars, is that anything I need to look for in particular to make a reverse camera work? TV/AV button?
- how many inputs does the LCD have? Possible to have a reverse camera and a AUX input?
Thanks guys, and if you have anymore details about install a reverse camera, please let me know.
:rolleyes:
Anthony
do a bit of a dig on my name - I think I covered most of this. rev camera is easy. if you have $800 I'll get you the OE pimple. the other way is to add one to it.
the 6 pin plug is the audio/video input . I have the correct leads (in stock) to make this painless.
click my sig for more info :rolleyes:
Hi, I have a Panasonic CN5000 TV/SatNav unit in my sedan. Do I need to throw the whole lot out (except the Pana Screen) to get the TV working?? The system has a hard drive and SD card slot, was hoping to load music onto it, just have to figure out the translation!!
Shame that the Sat Nav etc doesn't work here.....quite and impressive system
I have one of those here. I trashed the lot and reused the screen. the entire system is two pieces. NONE of it is useable and unless you have the electronics knowledge to reverse engineer the screen , bin it as well.
I dare say that you have a pocket under the system and a big pocket above the glove box where the OE unit is meant to be.
click my sig for more info :D
Thanks, but I can't seem to find any info you mentioned.
I had a good search through the forums, including searching for your posts but still cant find info on installing a reverse camera.
Any chance you can link to them for me?
Much appreciated.
Thanks
Anthony
ok I'll do it here. system runs RGBs so you need a magic box to make it work correctly and a camera. the OE one that you see on the rear of most cars does this.
as for doing it from dry - how electrically minded are you?
Thanks Chris!!
I pretty good at electronic and shouldnt have problems wiring things up.
I used to have a R33 GTS25T and use to spend heaps of time on it, but was written off in a accident.
And now I m craving to work on something, so time isnt an issue either.
All I need is good instructions and I should be good to go.
its a bit more than that. you will need to find a diagram for the car. from there get all the bits ( I can supply these.) and go from there.
give me a call and I'll go over a few things with you ( 0407-102-839.)
Hi there,
Good to see so much discussion is taking place to improve the 350GT
I might be totally wrong here but here it goes.
My understanding of the TV setting is quite differ interms of broadcasting method for each country.
For example:
Japan: ISDB-T
Korea: T-DMB
Europe: DVB-H
USA: MediaFLO
Australia: DVB-T
These are not your analogue signal but digital signal currently used in most of mobile devices.
Australian signal is not compatible with ISDB-T if I am not mistaken, thus no point of fiddling with TV tunner.
But SatNav would work regardless as long as right GPS Map for the host unit can be found.
Cheers,
DY
  • 7 months later...
Hello,
I dont know if i missed it, but can you make the screen automatically display the reversing camera when placed in reverse?
What would you require to do so?
How does the factory system do this?
Also which wires do you need to disconnect to make the TV stay on all the time when driving?
Thanks
Pete
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
