This is just awesome,
I got my iphone connected and got Tom Tom to be displayed onto the screen.
Now I just need one of those bypass harnesses, so Tom Tom will continue to be displayed even whilst I am driving instead of automatically switching back to the Japanese navigation screen.
So I assume this harness is just plug and play and no further modification/ wire cutting? No need to cut the e-brake wire or speed sensor wire?
Great !
Same setup I'm wanting to do, Can you let me know how your answering phone calls ? eg. Bluetooth Handsfree kit and is sound transmitted through the car speakers ?
Hows the GPS lag ? Bearable ? There are external Blueooth GPS Receivers that work with the iPhone but would stop your ability for a bluetooth kit.
  • 4 months later...
hey guys, I own a 04' v35 skyline 4 door sedan, cant locate the tv control unit, its not in the boot or under passenger side dash, can anyone help me out? thanks
Under the parcel tray in the boot on the right side. (ie, right below the back windscreen)
hey thanks, I wired this up today but im only getting black and white picture, can anyone help? thanks
What TV tuner are you using..?
If it is the Asuke you can change the input (NTSC /PAL) through the menu.
Cheers
Andy
my tv tuners the late model one, start with a 4...... if i could change settings that would be great!!!
sorry, I don't understand your reply.
The standard TV tuner in your car will not work as it is set to work on Japanese frequencies.
If you want TV in Australia you need to connect to the tv tuner an Australian frequency tuner that outputs in NTSC.
These are available in Australia through various group buys.
whats that asuke thing you wer saying? thanks
The Asuka Hawk Range 2 (or 3) are an aftermarket Digital TV tuner that you need to install in your car that will allow you to receive Australian TV stations.
  • 1 month later...
  • 3 weeks later...
Very nice write up.
I hope you've updated your ipod by now lol
LOL Not really.
I am not fan for Apple, this Ipod is for my wife and she is happy with it.(She only use it once a week etc.)
LOL
Frank
all that lead does is allow audio/video into the TV unit. nothing more. I do not ship O/S.
Thanks. Do you know where I can source a similar lead from? I'd rather plug in a cable than go wiring wires in.
pepsi..
http://kanatechs.jp/english/distributor/index.html#cgl
give them a call.
you need:
http://kanatechs.jp/ax/n01v.html
which for them *MAY* be a special order but they are able to get it.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
