I installed the reversing camera (CCD from eBay $29), and set up a relay to short Cont2 when in reverse. It works well, however I have noticed that thye shorting of Cont2 actually puts the car screen automatically into TV mode, so I have to switch back manually if I was in another screen. This shoudlnt be a pro9blem when I install the computer, but is kind of less than perfect for now.
Does anyone know if shorting Cont1 does the same thing?
It gets highlighted by the fact that every time you move from park to drive, you have to pass Reverse, so it shorts Cont2 for a split second (enough to put it in TV mode).
Sorry for the blurry image, but it was a quick snap.
I see what you're saying. I never noticed because my default is with TV on.
Just went & checked on my M35. With the screen on the trip meter screen, moving thru reverse puts earth on C1 and brings up camera as it should. Then when moving out of reverse it stays on the TV screen & plays live tv as you said. If I wanted the fuel consumption screen I would have to push a few buttons. I see your point.
BUT, if I move the gear selection lever "briskly" past reverse the screen will stay where it was. That could be your answer.....?
Are you shorting Cont1 or Cont2? I went for Cont2 as it was considerable easier to get to.
I think my answer will be to put a delay (say 0.5 seconds) on the relay shorting Cont2.
I did try moving the gear lever fairly briskly, and it still flipped over. I am using a very small 12v reed relay for shorting Cont2.
Mine is called C1 (equivalent to your Cont1) but AFAIK they are both the same, regardless of what they're called.
My relay is a big one (40A) so maybe it reacts a little slower than yours. I did have to be pretty quick on the gear lever though.
  • 1 month later...
Learnt a new thing about this grounding of Cont1. If you leave Cont1 grounded while the car is starting, it wont go to Audio - AUX. It appears that you haver to let the cars computer/TV module boot up, before grounding Cont1 works as expected.:dry:
Well, there you go... That could be helpful for those with an OEM stereo to know (not me :happy: ). So how did you get around it? Do you manually switch it after you start?
I plan to manually switch it for now. Long term plan will be to put a timer and relayed breaker on the grounding wire for cont1; but letting the reverse camera bypass the breaker. I think the delay only needs to be a few seconds, but havent timed it yet.
I can leave it for now, as I will set up my car pc to automatically start playing music on resume from hibernation, so I shouldn't need to see the screen of the PC.
And by the way, when I say it wont go to Audio AUX, i mean you cant even select it using the mode button on the stearing wheel, until after you leave it ungrounded for a few seconds.
  • 4 weeks later...
Out of interest, can you actually use/read the screen when connected to your car PC? i hooked my laptop display up to the screen via a converter and the picture was rubbish.
Edited by Tricky-Ricky
yeah ntsc for all inputs. due to this, my PAL xbox 360 only comes thru in black and white... omg its the end of the world :P
and the composite output on a laptop is usually pretty poor.... the s-video ones are worse still, and then you have to use a s-video to composite adapter... makes the video output very fuzzy looking
Edited by Deep Dish V35
Yep its very useable, but not perfect. There seems to be some interference coming through, which was worse before I replaced a cable with one of those expensive monster cables.
I have been meaning to post some pics/vids, hopefully this weekend.
The video card I am using has an S-Video out, and a small converted plug to composite. This may be the cause for some of the fuzzyness I am seeing. I need to find anpother video card that has composite out, but this is considered "old technology" as most cards now only have digital outs (HDMI or DVI)
  • 1 year later...
Has any one fixed the problem so you can watch Video with the hand break off??
You can either cut the speed sensor and earth the handbrake wire behind the dvd rom or get it done programmaticality.
It all depends where the video is coming from? I do not use the built in TV, as it only tunes to JP channels, however, I always reverse without the handbrake on, and if they wanted to, the passenger could watch videos while the car is moving. From memory, all I did was ground "Cont1" Edited by vee35
I have read through this entire thread - and it appears the answer to my question might be only a recent find.
I want to buy a reverse camera off ebay - and have it show through the stock headunit automatically when reverse is selected.
I don't care about TV or NAV or anything like that - just want reverse camera as i park in a lot of tight spaces.
correct me if i'm wrong here but the solutions is:
1) Run Video-In to spare Aux in factory TV Tuner and ground Cont 1 using a relay driven by reverse lamp 12v.
The draw back being that once the reverse camera image shows up, you need to manually switch stock head unit back to another menu to get rid of it??
Has anyone got any further than this? Is there a magical cable that Chris Rogers has that can take this pain away!?
"you need to manually switch stock head unit back to another menu to get rid of it"
I'm not sure what you mean by this. I've put a cheap ebay camera on my car, connected it to the video in pins on the factory TV tuner, and used a relay to ground cont1 when the reverse lights come on. I powered the camera from the reversing lights as well, so it only has power when I'm in reverse.
When I select reverse, the camera video output automatically comes onto the screen. When I change out of reverse, the video shuts off, and the screen goes back to the nav display (which is of no use as it only has Japanese maps). If I want to view an info screen, I have to select it, every time I shift out of reverse.
I'd like to find a way to have it automatically select the info display, rather than the nav display, when I shift out of reverse. Other than that it works great. I think the camera was around $15 off ebay, and it has IR so works well at night. It's mounted at the top of the number plate, and is very effective.
If anyone knows how to setup the system to automatically chage to the info screen, I would be eternally grateful.
Cheers
He means exactly what you have just said (and also what I have said) - that the reverse camera displays fine - but once the car shifts out of reverse it doesn't return to the info screen - it goes to the tv input.
Edited by SMOKEYC34
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
