Hi Frank, can you please explain a little more clearly about the pin outs from the TV Control unit
The plug looks like this : . . : (each dot represents the pin)
Starting from the left, can you please advise what is a ground, video in, left audio in, right audio in etc. Thank you!
1st Top Pin -
1st Bottom Pin -
2nd Bottom Pin -
3rd Bottom Pin -
4th Top Pin -
4th Bottom Pin -
JK
1st Top Pin - audio Right (core)
1st Bottom Pin - audio Lefr (core)
2nd Bottom Pin - Ground
3rd Bottom Pin - Video in (core)
4th Top Pin - Shield
4th Bottom Pin - Named: VTR- Has no idea what it is, Unused
also DO NOT UNPLUG THE YELLOW PLUG! It is the airbag for the passenger side. you will set a light (fault code) if you do and turn the IGN on!
Thanks Chris.
I almost unplug it .
Luck I am not.
Hey Frank,
Would you consider doing another car? Mine is the 05, non BOSE but should be similar. I'm in Syd as well.
PM me if you like on how long it will take and your price.
I can take everything apart and help you as well, but am pretty hopeless with the rest of it.
Cheers
Bobby
Frank,
the SHIELD pin - where does this connect to?
Also do you run ground to all 3 RCA grounds or to EARTH ground?
Thanks
Jai
Hi jai:
For the compsite, they used shield coaxial cable, so the core is the core of cable, shield is the shield.
We suppose to used this kind of cable, but it is too big and will be very difficult to hide somewhere, instead I choose the flat shield cables.
In the flat shield cables, each one has a core and a shield, so we can just joint 3 shields into one.
Please correct me if I am wrong.
BTW: Chris: can I ask, Do we have to go the ground?
Edited by Frank350GT
Hey Frank,
Cheers
Bobby
NISMO:
Thanks for supporting, Sorry I am not a perfossional people in this business, it cost me about 5 hourse to make them done. But I believe next one I can finished in 2 hours, If skilled people like chris do the same job with right tools, I bet 1 hour is enough.
This the first time to me either, trust me, you can do that your self either.
or move the standard DVD drive behind the dash (as its useless anyway) and put a factory-looking DVD+TV unit into the stock DVD location :rofl:
some aftermerket DVD units come with a remote and IR sensor that plugs into the back of the unit and can be mounted anywhere on the dash, that way you can navigate the DVD drive while the upper glovebox is closed
NISMO:
once I'm done 30 min or less with instructions will be the norm.
mine will plug straight in and have a choice of 3.5 mm plug or rca plugs depending on application.
give me a bit I'm waiting on an answer (and waz is waiting on his lead :rofl: )
Edited by Chris Rogers
...and waz is waiting on his lead
you know its funny i initially didn't even want the reversing camera.. given i thought it looked like a pimple on a model's face
but now that its not useable, i can't imagine living without it!
this might even be a good opportunity for others without a reversing camera to hook up somethign aftermarket given we now know how it is hooked up
Yep, the most I spend on make the connectors and RCA scokets.
Damm, everything is tiny.
yep!. thinkI figured yours out :rofl:
I'll tell you more once I get your lead back to you.
it is. fun part for me is going to be making them and getting the crimps right. :rofl:
give me a bit I'm waiting on an answer (and waz is waiting on his lead :) )
thanks Frank,
Chris, will this be a plug and play for the series II as well?
Bobby
howie are you watching the thread while thinking about buying a V35.... thats why i am always lurking
Frank.. TOP effort.
Thanks.
Have a look a t the newest issue of HOT4's, you will get dep understanding of V35, from WA's C-WEST 350GT
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
