Hi,
Ive decided to buy a new fuel pump this week and just wondering if the R32 GTR fuel pump would be any good. Some people are saying they are a good replacement but wouldnt it be dieing just like the one I have now? I have a standard Gts-t fuel pump but both pumps are the same age? Would the GTR fuel pump run alot better? Or would it be dieing as well?
https://www.sau.com.au/forums/topic/184372-r32-gtr-fuel-pump/
Hi,
Yes an R32 GT-R pump is a good upgrade.
There is no reason to suggest that the pump in question would be on its way out. People upgrade their Gt-R pumps when upgrading their motors, so if you ask the seller (nicely) & check on the kms/age of the unit you will be fine. They are a direct fit (afaik) & given the prices you can't really go wrong.
Would the GTR fuel pump handle 200rwkw without any problems? Im nearly on 200rwkw at the moment and still going to finish the exhaust. Just wanna make sure i wont get any pinging in my engine... my pump at the moment isnt doing very well....
Short answer. Yes. Does is easilly in a GT-R.
Cheers!
Im thinking of buying one today, Would it be a direct replacement in a R32 Skyline? Would i need different wiring? or a different bracket?
As far as I know, it should be a straight swap over. Might need a little modification to the bracket, but it shouldn't be too hard.
A good condition GTR pump should get you to the 200rwkw mark safely.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
