is your fan still working properly sometimes they wear out or lose there fluid. a simple test is drive at 100km for long extended periods of time and see if your water temp goes down. is your pump still pumping enough flow this also could of broke down. just a few oter ideas to check out. just start eliminating one by one i like to start with the cheapest >_<
had similar issues with my 34 not long ago.
i went a new radiator, oil cooler and lower thermostat.
bit to spend but had no problems since.
factory gauge was little use compared to power fc which monitored much better.
Ben,
Let me know how you go with flushing the radiator please.
Will be taking it in tomorrow.
The machanic doing all my mods has checked the oil and it is all fine, so if this
doesn't work I will be getting a new radiator
  • 3 weeks later...
i just experienced the same problem and its just been fixed .... sorry for the long post but I couldnt fit it in 2 lines
car = r33 gtr
problem = oil temp up to 110-130 (normal driving), boiling coolant, water temp hitting 3/4 level at times (yes turning the heater on kept the temp to 1/2 way which was normal)
diagnosis from a well known tuner in sydney = free wheeling viscous coupling (so i ordered one from nissan at a cost of $440!!!) not happy jan..... + the cost of figuring out the problem $100
2 weeks into the wait and the same day the clutch fan arrives, the radiator starts leaking....so I baby the thing to the workshop (not the same workshop as mentioned above, never again!)
turns out the radiator is blocked (apart from the obvious leak that just started)
I ended up buying a new radiator from Justjap, change thermostat (old one was OK), changed clutch fan just because and i couldnt get a refund anyways (old one was also in great condition)
Now, my water temp is always below 1/2 way, oil temp just gets above the 70 mark on the gauge even with a bit of spirited driving and aircon on!!!!
Moral of the story, dont think a well known tuner can solve all of your problem! Had a feeling that the radiator was stuffed but decided to listen to the mechanics!
But what can you do, it is a GTR and I'd rather spend a few $ for someone in the know to figure things out rather than spending thousands to fix the engine!
Edited by jeff
I suppose its a good case of K.I.S.S hey? thanks for flling us all in .. as I am new to the concept of clutch fans ( as I am used to electric thermofans)
car = r33 gtr
Just an update on my prob....
It ended up being the bloody radiator after all that.
Instead of flushing it out i just bought a new 40mm thick one from Just Jap. Couldnt be happier with the result.
Now sits on 81 degrees usually.
jeff....how many letter in the workshop's name?
$300 from Just Jap or UAS for a new one can't be beaten...I had to buy a standard (aftermarket pathfinder) one for the race car and it was 450 trade price.
i noticed people in this thread talking about oil temps.
My r34GTT never goes above 80 on the standard gauge. just wondering as this seems pretty low compared to the 100plus figures here
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
