Hi just want to know what has caused my sunroof and mirrors to stop workin they both stopped workin at the same time are they linked in any way like with a Fuse or something. Where is the fuse for these to items? Any ideas? They where all workin fine not to long ago.
Help! thanks!
https://www.sau.com.au/forums/topic/184385-sunroof-and-power-mirrors/
mate, if more than one electrical thing breaks down at once then its 99% likely thatits a fuse issue..
have you checked your fuses? it would take you less time to check your fuses than it would to start up your computer, log onto SAU, and post up a thread
if all your fuses are normal then post back up and we'll see if we can help
Warren.
obviously, but i just wanted to know if there was a certain fuse it would be as last time i looked in fuse pannel was japanese wanted someone to point me in the right direction thanks! And since iam at work not at home with the car it would actually take less time to turn pc on thought i would just post see if anyone else has experienced the same problem.
ok cool are the sunroof and the mirrors both dependante on the same fuse? do you think this sounds like a fuse issue?
I would think that it's a fuse problem. Two things going out at the same time.....
There's a thread somewhere here on sau to show you what those Jap words on the fuse cover means. I remember getting the info from somewhere on here. Quick search and you'll find it.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
